21615 Discussions
How to set timing constraint for JTAG
XQSHEN
ak6dn
Valued Contributor III
Here is how I put timing constraints on a JTAG interface (I do it in an .sdc constraint file):
# JTAG setup for Altera USB Blaster
set_false_path -from [get_ports {altera_reserved_*}] -to CPUCLK
set_false_path -from CPUCLK -to [get_ports {altera_reserved_*}]
create_clock -name altera_reserved_tck -period 40 {altera_reserved_tck}
remove_input_delay [get_ports {altera_reserved_tdi altera_reserved_tms}]
set_input_delay -clock altera_reserved_tck -clock_fall 3 [get_ports {altera_reserved_tdi altera_reserved_tms}]
remove_output_delay [get_ports {altera_reserved_tdo}]
set_output_delay -clock altera_reserved_tck 3 [get_ports {altera_reserved_tdo}]
# Cut off paths between async clock domains
remove_clock_groups -all
set_clock_groups -asynchronous -group {CPUCLK} -group {altera_reserved_tck}
ak6dn
