21615 Discussions
I design a board with max10,and do not design the reset input for max10, how can I generate a internal reset ?
zlan01
Can I use the locked output of pll to generate a reset signal for my design? And what is the best reset mode for max10 ?using a input reset or generating a reset signal just in FPGA ?
For my board,there is no input signal, how can I generate​ a internal reset ,can you give me a example for that ,or where I can find the reference?
SreekumarR_G_Intel
Yes , you can use it , but you have to be careful since when clock fails or skew or jitter or any issue related to the clock; PLL will lose it lock and it will reset your system.
I am not following you , what you really menat by reset mode of max 10 ?
Can you refer to your another post , I replied to that
https://forums.intel.com/s/question/0D50P00004YEdCR/i-do-not-have-the-input-reset-signal-from-the-outside-of-the-altera-fpgaand-want-to-generate-reset-internallycan-i-do-like-below-
Thank you,
Sree
ak6dn
Valued Contributor III
Very simple to do. Init a register to '0' and have it drive the RESET~ signal (ie, an active low reset).
Then have a counter that starts at '0' and counts up for some number of bits (width depends on clock period and desired reset pulse width).
When the counter overflows (or hits some predetermined value) set the register driving RESET~ to a '1', which deasserts reset.
I have used this technique on various parts to, for example, generate a fixed 500ms reset pulse on FPGA powerup/configuration.
No external reset input signal required.
I used the onboard PLL to generate my system clock from the external 50MHz crystal oscillator input. I also used the 50MHz clock input to drive the reset generation logic (so it operates independent of the PLL).
zlan01
oh,thanks very much!
what about use the output of the pll to driver the reset generation logic ?
Can the code below generate a reset correctly?
always@(posedge sys_clk ) //sys_clk is a output of the pll and is 200Mhz
begin
  if(~locked_sig)
   reset_cnt <= 30'd0;
  else if(reset_cnt < 30'd200_000_005 ) // 1second to configure
   reset_cnt <= reset_cnt + 30'd1;
end
assign rst_n      = (reset_cnt     == 30'd200_000_001)?1'b0:1'b1;
ak6dn
Nope, I don't like that approach. Can't rely on SYS_CLK being valid if PLL is not locked.
Here is what I do. I generate an async reset at powerup ONLY. Sync to PLL clock via dual rank sync circuit if sync reset is desired instead.
// PowerUP Reset Logic   // generate a 500ms reset pulse on initial powerup   `ifdef SIMULATION reg [24:0] pup_count = 25'd24999900; `else reg [24:0] pup_count = 25'd0; `endif reg pup_reset = 1'b1;   always @(posedge CLOCK_50) begin pup_count <= #TPD pup_count + 1'd1; if (pup_count == 25'd25000000) pup_reset <= #TPD 1'b0; end   wire reset = pup_reset;
 PLL logic looks like this:
// Altera PLL Clock module   // Transform external crystal clock to our internal CPU clock   wire pll_locked; wire CLOCK_CPU;   pll pll ( .inclk0 (CLOCK_50), // input clock .locked (pll_locked), // status output .c0 (CLOCK_CPU) // output clock );   wire clk = CLOCK_CPU;
SreekumarR_G_Intel
Sure ....but my only cocnern is what is the initial value of the counter register PUP_count ?
Thank you ,
Sree
zlan01
to intel engineer
the sys_clk is 200Mhz, and the initial value of the counter register is 30'd200_000_005 need about 1 second to count,
I want to know :
1) which implementation is better , ak6dn's(directly using the input clcok ) or mine ?
2)if using ak6dn's, and the pll has several output clocks, the asynchronously asserting and synchronously desserting must be done according to different clock domain,right ?​
3) what is the intel oppion about that whether a input reset pin should be used or not ?
ak6dn
To SREE: the initial value of PUP_COUNT is zero. Why is this a concern?
To ZLAN01: My logic generates an async reset signal which can be used to async reset registers in any clock domain. If you want a sync reset instead, just run the async reset thru a dual rank synchronizer for the specific clock domain. You may have just one, or possibly even more. So it depends on how you write your system logic (w/ async or sync reset).
SreekumarR_G_Intel
Usually it is good to know the state of register to the known value ; Can i know how to find the PUP_COUNT value once power ON and no clock fed to the sysytem ? I belive it is undefined in your case and clock started to fed counter will start from unknown value.
Also note : I am not saying this is going to happen but what i believe is there is chance it can happen.
Thank you,
Sree
ak6dn
SREE,
This assignment statement in the above Verilog:
sets the initial value of the PUP_COUNT register to zero. It does not require a clock, it is initialized from the POF file.
zlan01
SO, The enginner of intel means that the method giving 25'd0 to pup_count is not reliable ?
And the standard process for altera is to input a reset signal to the FPGA ?right ?
ak6dn
Honestly I don't know what Intel support person Sree is talking about. Maybe they misunderstand the issue.
I have assigned initial power up values to registers using the mechanism I illustrated for YEARS and it works just fine.
The reason to use an external reset signal input is if you want to reset the device state AFTER powerup configuration.
The value assignment to the register is only good after configuring the device (at powerup or anytime a reconfig is triggered).
If you want to do a device reset at an arbitrary time, and not have to force a device reconfiguration, an external reset signal is good for that.
And as I said I have no idea what Sree was referring to. His/her response is basically WRONG.
SreekumarR_G_Intel
Hello all,
Sorry i was caught up into different stuff ,
Actually in synthesis world reg [24:0] pup_count = 25'd0; is doesnt mean anything. if you think how you infer this as hardware i am not sure how to design or i can say there should be some define state to make sure it is set to Logic 0 or 1.
I have to check the LRM and Quartus synthesis tool to confrim by deafult the state of the reg type signal.
Also reg [24:0] pup_count = 25'd0; only used in Simulation not use in synthesis.
Hence if you want your design have valid state at reset kindly consider to use external Reset.
Sorry delay in repsonse again.
Thank you,
Sree
ak6dn
Sorry Intel support person Sree you are misinformed and do not know what you are talking about.
I have been using the construct reg [24:0] pup_count = 25'd0; for YEARS now in the Quartus synthesis tools (at least since 11.0sp1) to assign the default initial powerup configuration of a register.
Using the external reset pin to feed into the async reset of a register is NOT necessary. The above construct works just fine for an initial powerup configuration.
Using the async reset pin is ONLY necessary if you want to perform that function AFTER initial powerup configuration.
