Programmable Devices
21594 Discussions
Is it possible to access loanIO of hps from a fpga ip core with bidirectional IO?
Mingyuexin
I have a customized design which I have routed a NVRAM to SPI pin of HPS side.
Now the software team wants to access NVRAM like a flash. So I'm thinking to use generic flash controller ip core in FPGA to control it. I know it's possible to loan pins from HPS to FPGA.
The issue here is :
The generated conduit signals supposed to connect to FPGA are only unidirectional, see
._hps_io_gpio_inst_LOANIOXX   Bi-direction              to top level pin assignment
._h2f_loan_io_in                            Out                              to FPGA logic
._h2f_loan_io_out                          In                                to FPGA logic
._h2f_loan_io_oe                           In                                 to FPGA logic
But the generic flash control ip has bidirectional IO for data transfer. It seems I can not connect them together. Is there any solution for this? If not, then I have to redesign the board to use FPGA pin instead.
Thank you very much for your time.
Any response/reply is appreciated.
Mingyuexin
EBERLAZARE_I_Intel
May I know the Quartus version you are working with?
Also, which board are you referring to? Is It Cyclone V SoC, Arria 10 SoC etc
Mingyuexin
Thank you very much for the response.
I'm working with Quartus Prime standard 18.1.
My board is Cyclone V SOC.
Best regards
Mingyuexin
Mingyuexin
Do you have any solution or suggestions on this?
With best wishes
Mingyuexin
EBERLAZARE_I_Intel
Accord to our Cyclone V SoC Device Design Guidelines, the recommend peripherals that the HPS dedicated IO with loaner are: QSPI, NANDx8,eMMC, SD/MMC, UART,USB, EMAC
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/an/an-cv-av-soc-ddg.pdf#page=17
NVRAM is not entirely supported. But you may check our video tutorial on how to initiate the example of HPS loaner IO using Qsys/Platform Designer here:
https://www.youtube.com/watch?v=cRwzmsJ1Jkg
taojinyong
I have a question. For Arria10 devices, I don't see the LOANIO option, and my quartus version is 18.1
Mingyuexin
Sorry I have never used Arria 10, I do not know.
Best regards
Mingyuexin
open01
Hi Mingyuexin,
Want to ask this question, have you found the answer? I also want to know this part.
Thank you.
Mingyuexin
Sorry to see your question this late.
We redesigned the hardware to use FPGA fabric to communicate with the flash.
With best wishes
Mingyuexin
