Programmable Devices
21602 ディスカッション
JTAG and/or IO pin usage
名誉コントリビューター II
5,054件の閲覧回数
Hello all,
I'm new to CPLDs but I'm very keen on getting a little project up and running soon.
The basic question is: is it possible to program a EPM3064 through the JTAG pins, then use the JTAG pins as IO, then later reprogram it?
I'm planning on using the EPM3064 CPLD and I'd like to be able to program it through a microcontroller eventually (I'll have a JTAG connector for a USB blaster during development though - so that's not an issue... yet). The uC has 8 pins connecting to the CPLD to select the operating mode, 4 of which could also connect to the JTAG pins. I only need 7 bits for the actual mode selection - so if it's not possible to switch the JTAG pins between JTAG & IO mode - perhaps the 8th pin could go to the JTAG TCK & if never toggled in normal operation, maybe it will work?
Thanks in advance for any info.
Doug.
0 件の賞賛
10 返答(返信)
名誉コントリビューター II
3,883件の閲覧回数
You can connect the pin which drives the JTAG pins to other IO if you're careful, but you can't reuse the pins themselves.
The safest way is to share TCK with another clock, and tie TMS high when not in JTAG mode. The MAX will then ignore TDI and tristate TDO.
An alternative is to tie TCK either high or low, while using other pins as IO. The MAX will ignore TDI and will probably tristate TDO, but if you get noise on TCK then it could get into a state where it drives TDO.
名誉コントリビューター II
3,883件の閲覧回数
As far as I understand, disabling JTAG pins is possibly with MAX CPLDs, but strictly one-way. After that, you can't reprogram the device with a standard JTAG programmer, a special high voltage pin function (e.g. available with a Altera Programming Unit) is required to reenable JTAG.
名誉コントリビューター II
3,883件の閲覧回数
Hi wombat & FvM,
Thanks for the replies. If JTAG can't be reenabled easily I won't bother disabling it.
Ok, I'll try with GCLRn & TCK tied together; so whenever I want to reset my CPLD I'll pull TMS high and clock TCK until the TAP's in test-logic-reset and the all my registers have been cleared. The I presumably have TMS/TDI/TDO available for inputs? I might connect TMS/TDI/TDO to some other IO points initially in case they're not available.
Thanks again,
Doug.
名誉コントリビューター II
3,883件の閲覧回数
--- Quote Start ---
--- Quote End ---
Look at the pinout for the device;
http://www.altera.com/literature/dp/max3k/epm3064a.pdf
The JTAG pins are dedicated pins that cannot be used as I/O afterwards.
If you want to reuse the JTAG header on the board to access I/O pins on the FPGA, then that is definitely possible; see page 8 of the attached schematic for an example. In this scheme, a 2-pin header is either attached or removed to route the signals to JTAG pins or to I/O pins.
Back when you could interface to JTAG using the parallel port, I used to use an unused pin on the ByteBlaster cable to select the operating mode (via the HDR_JTAG_SEL signal), however, the newer USB-Blaster cables cannot easily be re-tasked as a general purpose digital I/O interface (though I'll figure it out one of these days ...). Make sure the resistor on the HDR_JTAG_SEL signal is a no-mount, as it seems to confuse the USB-Blaster.
Cheers,
Dave
名誉コントリビューター II
3,883件の閲覧回数
--- Quote Start ---
--- Quote End ---
Oops, my bad, I didn't read note (1) :)
It looks like you can use them as I/O. But perhaps as FvM suggests, its only if you disable JTAG. In that case, you can use the scheme I mentioned.
Cheers,
Dave
名誉コントリビューター II
3,883件の閲覧回数
Thanks Dave for the notes.
That's a little confusing for me (note 1 in the altera doc, I can only guess that 'configured for isp' means entering the programming mode). I'll just treat the JTAG port as if it's always a JTAG port then, and double-up the JTAG connections to spare IO (which I have heaps of) and be done with it - easy!
PS, no I don't want to reuse the header - in fact I want to get rid of the header & connect some uC IO to the CPLD with the same uC IO doing JTAG-y stuff as well as mode selection for my user code.
I think I'm sorted now though.
Cheers,
Doug.
名誉コントリビューター II
3,883件の閲覧回数
--- Quote Start ---
--- Quote End ---
That is generally the best way to do things.
--- Quote Start ---
--- Quote End ---
In that case, check out the JTAG-y stuff in this schematic:
http://www.ovro.caltech.edu/~dwh/carma_board/gda06rb004_carma_v0.87_dec03.pdf (http://www.ovro.caltech.edu/%7edwh/carma_board/gda06rb004_carma_v0.87_dec03.pdf
Why are you thinking of using this particular CPLD?
The MAX II devices are much nicer, eg., EPM570 in a TQFP 100 package. When I want a little glue logic, I find that one quite handy. The schematic I just referenced to uses a couple of them.
Cheers,
Dave
名誉コントリビューター II
3,883件の閲覧回数
--- Quote Start ---
--- Quote End ---
Great!
--- Quote Start ---
--- Quote End ---
1) I need the 5V-tolerant inputs
2) because it's still pretty cheap (I was originally looking at the epm3032 which is very cheap, but alas too small)
Cheers,
Doug
名誉コントリビューター II
3,883件の閲覧回数
--- Quote Start ---
--- Quote End ---
Fair enough. I'd place-and-route your CPLD design before making any final decision (since the part is a logic cell light-weight). If you need more logic, then you can use bus-switches to get 5V tolerance. The schematic I referenced has a 5V tolerant, hot-swappable, compactPCI interface.
Cheers,
Dave
名誉コントリビューター II
3,883件の閲覧回数
--- Quote Start ---
--- Quote End ---
--- Quote Start ---
--- Quote End ---
Unselect the "Enable JTAG BST support" option in "Device and Pin Options/General Tab". Then the four JTAG pins are available for assignment as general I/O.
I agree, that the description of this feature in the device hardware manual isn't particularly clear. I didn't try it yet, but it's obvious to me, that the JTAG functionality can't be re-enabled with standard low voltage levels, otherwise the usability of the respective I/O pins would be restricted.
返信
