Programmable Devices
21593 Discussions
License status seems not to be working
Had setup the floating license correctly, however we can't see the licenses in use as reported by the utility (see the attached .jpg). It only reports the licesnes he has avaialbe but he claims while someone is activly using quartus and he runs the report he's not seeing any usage ever.
Any ideas need to be to do next?
Thanks for any help in advance
next you should look at the floating license server log to see if the expected licenses are checked out then in
