Programmable Devices
21611 Discussions
MSGDMA tx descriptor send procedure: (for pc2Fpga transfer data )
JET60200
Hi experts,
our Arria10 works as a 10GE NIC in x86 Linux PC.  we implement  "TSE + MSGDMA" to transmit ethernet packet from linux pc  to  FPGA,  MSGDMA will move packet from PC to FPGA, then then the TSE Module will generate ethernet packet out.
But I have a question regarding of  “MSGDMA tx descriptor ” issue sequence and conditions :
(1)  firstly our linux driver will creates a "tx-descriptor " in msgdma_tx_buffer() ,  then fill in every elements of " msgdma_extended_desc{..}" (as following) .
    csrwr32(lower_32_bits(buffer->dma_addr), priv->tx_dma_desc, msgdma_descroffs(read_addr_lo));
    csrwr32(upper_32_bits(buffer->dma_addr), priv->tx_dma_desc, msgdma_descroffs(read_addr_hi));
    csrwr32(0, priv->tx_dma_desc, msgdma_descroffs(write_addr_lo));
    csrwr32(0, priv->tx_dma_desc, msgdma_descroffs(write_addr_hi));
    csrwr32(buffer->len, priv->tx_dma_desc, msgdma_descroffs(len));
    csrwr32(0, priv->tx_dma_desc, msgdma_descroffs(burst_seq_num));
    csrwr32(MSGDMA_DESC_TX_STRIDE, priv->tx_dma_desc, msgdma_descroffs(stride));
    csrwr32(MSGDMA_DESC_CTL_TX_SINGLE, priv->tx_dma_desc, msgdma_descroffs(control));
   Once LAST "|GO" Bit is set into msgdma_desc(control),  MSGDMA start to transfer data.
【 My question 】:  after the first "tx-desc" is issued to FPGA , and MSGDMA now is working on it .  Now we have more tx packets coming in soon,  thus we need to revoke  msgdma_tx_buffer()  to start these new packet transferring,
Do we need check any "BUSY" flag of this MSGDMA,  or any else in STATUS REGISTER BIT(s) , to decide whether it's safe for usto  send the second -> third -> fourth -fifth . ....  tx- desc  to FPGA ?
Do we need wait for CSR  “STATUS REGISTER # BIT0 (BUSY flag) ” to be zero, then start the next "tx_desc", Or we dont need care that ?
Thanks a lot
AnilErinch_A_Intel
Hi ,
If you want to see the default settings with MSGDMA you can refer the below link
https://rocketboards.org/foswiki/Projects/AlteraSoCTripleSpeedEthernetDesignExample
If you want to know more step by steps procedure for executing a Linux driver for MSGDMA ,
you can refer to the link as below.
https://rocketboards.org/foswiki/pub/Documentation/WS3DevelopingDriversForAlteraSoCLinux/WS3_Developing_Drivers_for_Altera_SoC.pdf
Please share your observations after trying out the steps.
Thanks and Regards
Anil
