I have a serial video signal that I want to take into an FPGA, with a parallel clock that could range from about 20MHz up to 150MHz. I'm using an Arria II GX. Am I able to get the PLL in the FPGA's transceivers to lock to an unspecified frequency within that range? Cheers, AlexLink Copied
Alex,
The easiest way to handle this is to feed the data and clock into dual clock fifo. This allows the input data/clock to vary to any value. Then you can process with a fixed clock on the other side. No changes in the PLL input frequency.- Mark as New
I need to divide the parallel clock's period in order to sample the high speed serial signal. I thought I needed a PLL for that. Is there another way, using a dual clock fifo in the design? Cheers Alex- Mark as New
If what you need is a division and not a multiplication, then no PLL is needed. You can use a clock enable system instead. Put your parallel clock as the FIFO write clock, and only enable the FIFO's write signals on the clock cycles that have valid data on.
I assume, that you an DVI-like interface. In this case, a PLL will be obviously needed. Altera PLL specification doesn't provide a wide lock range as you are requesting, although the actual lock range may be considerably larger than the spec. A frequency discrininator and PLL reconfiguration can be a solution.
