21602 Discussions
Problem In Reading SSRAM On Cycone III
I am using Cyclne III Kit ... Which has External SSRAM on it. I am trying to perform read and write from it. I have coded small state machine which generates control signals to SSRAM.
The writes are working good in both RTL and Gate Level Simulation. But I observed Read is not happening in Gate Level Simulation.
I have seen data floating on DQ at Rising edge of the clock. But my registred read data is 32'hXXXXXXXXX.
Please anybody help to figure out the mistake ?
Ganapathi.
What are you using for a simulation model for the SSRAM? Which SSRAM device is on the board?
Jake
I am using IS61LVPS25636A SRAM simulation model. The SRAM on the board is IS61LPS25636A.
Hope your reply,
Ganapathi
Hi, were you able to use the SSRAM successfully?
i can't get the SSRAM to work properly, i can't write to the SSRAM properly. can i have some example code?
-AK
