Programmable Devices
公告
21615 討論
Procedure to add uClk_usr in Streaming DMA AFU
Navaneeth
新手
5,017 檢視
I want to run my AFU in uClk_usr domain in the Streaming DMA AFU sample example. Please can you provide the steps that need to be followed in order to achieve this.
Thank you
0 積分
29 回應
Navaneeth
新手
3,868 檢視
Any help is much appreciated.
Thank you
Navaneeth M
JohnT_Intel
員工
3,851 檢視
May I know which acceleration card and software stack are you using?
Navaneeth
新手
3,844 檢視
Accelerated card - stratix 10
Software stack - opae
JohnT_Intel
員工
3,843 檢視
If you are refering to https://www.intel.com/content/www/us/en/docs/programmable/683424/2-0-1/hardware-subsystems.html then the AFU is already connected to uClk.
Navaneeth
新手
3,828 檢視
We are referring to the same document. But I'm afraid they're using pClk for the entire design.
Specifically, we wanted a guide or a series of steps which will help us in taking uClk_usr signal as an input signal in hw/rtl/QSYS_IPs/avst_decimator/avst_decimator.sv file. The uClk_usr signal is present as input in hw/rtl/ccip_std_afu.sv but we are finding it difficult in order to correctly take it as input in the avst_decimator.sv file.
Thank you
JohnT_Intel
員工
3,814 檢視
Can you confirm if the "afu.sv" is using afu_clk?
Navaneeth
新手
3,806 檢視
Yes, "afu.sv" is using the afu_clk.
But, it would be great if the uClk_usr is made available in avst_decimator.sv file.
Thank you
JohnT_Intel
員工
3,800 檢視
Where can I get the avst_decimator.sv file? I am not able to see the file in the AFU design.
Navaneeth
新手
3,792 檢視
Path to avst_decimator.sv is:
<path to streaming_dma_afu folder>/hw/rtl/QSYS_IPs/avst_decimator/avst_decimator.sv
OR
$OPAE_PLATFORM_ROOT/hw/samples/streaming_dma_afu/hw/rtl/QSYS_IPs/avst_decimator/avst_decimator.sv
Thank you
JohnT_Intel
員工
3,775 檢視
May I know if you are using DCP 2.0.1? For this version, I do not see this IP
Navaneeth
新手
3,769 檢視
I am not sure about the DCP Version.
We are accessing the streaming dma afu folder by:
1. SSHing into devcloud
2. "devcloud_login" into "Stratix 10 PAC Compilation and Programming - RTL AFU, OpenCL" node
3. Performing "tools_setup" of "Stratix 10 PAC Compilation and Programming - RTL AFU, OpenCL"
4. cd "$OPAE_PLATFORM_ROOT/hw/samples/streaming_dma_afu"
The path to avst_decimator.sv is
"$OPAE_PLATFORM_ROOT/hw/samples/streaming_dma_afu/hw/rtl/QSYS_IPs/avst_decimator/avst_decimator.sv"
Expanded path is "/glob/development-tools/versions/fpgasupportstack/d5005/2.0.1/inteldevstack/d5005_ias_2_0_1_b237/hw/samples/streaming_dma_afu/hw/rtl/QSYS_IPs/avst_decimator/avst_decimator.sv"
Thank you
JohnT_Intel
員工
3,761 檢視
Could you try to download the official version and check if you can work with the latest AFU design?
Navaneeth
新手
3,751 檢視
Upon checking, the "avst_decimator.sv" file does not have user clock as input in this version as well.
Thank you
JohnT_Intel
員工
3,750 檢視
Sorry, I was looking at the wrong directory. After looking at the correct directory then I am able to find the file.
You can modify the file in ccip_std_afu.sv so that the AFU IP is using UserClk and not Pclk.
Navaneeth
新手
3,734 檢視
We tried using uClk_usr instead of pClk in line 117 of "ccip_std_afu.sv" file. We got the following error when we ran the software in simulation mode:
Thank you
JohnT_Intel
員工
3,720 檢視
It looks like the PCIe IP is using PCLK and the AFU is running using uclk_user which is not able to match the frequency. You will need to implement clock crossing to make sure that the clock is able to pass to the AFU design without any issue.
Navaneeth
新手
3,710 檢視
Could you please list the steps in order to implement clock crossing.
Thank you
JohnT_Intel
員工
3,689 檢視
After further checking, the rtl should not be change. You will need to modify the json file so that it is using uclk_usr. You may refer to "hello_mem_afu" example design json file.
Navaneeth
新手
3,675 檢視
Can you please tell us the location of the SDC file in the streaming dma afu folder?
Also, could you please tell us the additions that we have to make to the SDC file?
Thank you
回覆
