21584 Discussions
Quartus Prime timing analyzer identifying reset nets as clocks
bhunt
Hi there,
I'm having an issue with timing analyzer in Quartus Prime 18.1_SP1. (I'm forced to use this version for product software acceptance reasons).
A few reset nets are detected as clock nets, and show up in the Unconstrained Clocks report. How can I resolve this in the SDC constraints? Simply adding min/max delays doesn't resolve it (but I thought they would be appropriate for a reset net). I don't think it's helpful to define them as clocks since that would overconstrain the design.
Bhunt
sstrell
I think you should look closer at why they are being interpreted as clocks.  Can you post some code?  If you have put resets in the sensitivity list with the intention to create asynchronous resets (my guess), you have to code them appropriately so they don't get interpreted incorrectly.
ventt
Can you please attach your project .qar file here for us to evaluate?
Best Regards.
bhunt
Is there an easy command to report all the clock loads (e.g. clock pins) on a net?
ventt
You may check out the documentation below.
Intel® Quartus® Prime Pro Edition User Guide: Scripting
https://www.intel.com/content/www/us/en/docs/programmable/683432/22-1/tcl_pkg_sta_ver_1-0_cmd_report_clock_network.html
Intel® Quartus® Prime Pro Edition User Guide: Timing Analyzer
https://www.intel.com/content/www/us/en/docs/programmable/683243/22-1/report-clocks-and-clock-network.html
Ven Ting
bhunt
Thanks, this was very helpful! I'm all set.
ventt
Do you have any updates on this?
Ven Ting
ventt
I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread.
Ven Ting
p/s: If any answer from the community or Intel Support are helpful, please feel free to give best answer or rate 9/10 survey.
