21602 Discussions
USB Blaster breaking memory integrity protection on Windows 11
StarSword
I had to install USB blaster to run a Turasic DE-10 Lite board for a college class, and now Windows security is throwing a warning that the drivers are incompatible with the memory integrity feature.
Running Windows 11 64-bit on a laptop.
ak6dn
Valued Contributor III
Technically Quartus software is not yet qualified / supported running on Windows 11, so don't expect it to work.
Fakhrul
Hi StarSword,
Yes, as ak6dn mentioned above, it is not officially supported yet in Windows 11.
You may check in the following link for the driver's information. No Windows 11 has yet been mentioned for  OS compatibility. So, you may aspect some issues if it is installed in Windows 11.
Cable and Adapter Drivers Information
You may also check the link below:
Operating System Support
Hope this clarifies your concern.
Fakhrul
