Requirement
SANTHOSH1
Hi Team ,
we required the below part for one of our running parts  please let me know the availability
Mfr Name MPN Total Quantity
Intel EPM7064SLC84-10 5000
NurAiman_M_Intel
Thank you for contacting Intel community.
Please be noted that the part number mention was EOL since 2017. Kindly refer to PDN1619;
https://www.intel.com/content/www/us/en/support/programmable/support-resources/quality/fpga-pcn-pdn-adv.html?s=Relevancy&q=1619&f:@emtcontenttype_en=%5BProduct%20Discontinuance%20Notices%20(PDN)%5D
Aiman
ak6dn
Valued Contributor III
As noted that MAX7000 part went EOL about 5 years ago.
However, there is a pin and functional compatible drop in replacement offered thru MicroChip/Atmel.
It would be the ATF1504AS-10JU84 which is still a production part.
However, lead time is currently quoted at 94 weeks thru several distributors (Mouser, DigiKey).
So even tho it is not EOL like Intel/Altera, it is basically unobtainable in the next year or two.
You can use the MicroChip/Atmel POF2JED tool to convert an Altera .pof file to the required .jed file for programming the Atmel device.
So it is a technical solution as a drop in equivalent part, but in practice may be nonviable because of market conditions.
NurAiman_M_Intel
We do not receive any response from you to the previous answer that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you
