Programmable Devices
21615 Discussions
SOPC , trouble with memory
Hi , i have problem with SOPC builder. On first picture label : "Error: cpu_0: Exception is too large for the selected memory" Project : https://yadi.sk/d/q4-scbq13gsbnd
hello
the reason is that your memory is too small.
you have just 20 byte on onchip_memory2_0.
what a hell do you think you can do with it.
--- Quote Start ---
hello
--- Quote End ---
I changed the memory settings , nothing has changed
Thanks , I solved this problem long ago , but now i have another. In IDE : image on board is newer than expected
ok then, congratulations.
about your next problem.
I don't know where/when you meet this message.
you should describe detail.
--- Quote Start ---
--- Quote End ---
In nios ii ide , when i try to run project
upload your project again if you can.
