21615 Discussions
SignalTap -> Data Depth set to 0 -> when useful?
amildm
Valued Contributor I
Hi All,
In SignalTap there is an option to define the Data Depth to '0'... When is this option useful?
Thank you!
ShengN_Intel
When sample depth 0 is selected, no ram is needed. In that case, STP becomes a simple logical condition test tool. The waveform viewer still tells you whether condition is met or not, instead of drawing waveforms.
Sheng
p/s: If any answer from community or Intel support are helpful, please feel free to mark as solution and give Kudos.
Vic3Dexe
Sample depth? Hmm.. Never paid attention.
Now I'm curios too )
What exactly signaltap shows when sample depth = 0? I can't check it right now myself.
amildm
Vic3Dexe
Yes, I get it.
I'm asking what is the actual picture when you press "run analysis"?
amildm
With Data Depth of 0 it seems nothing is captured.... So the question was when the Data Depth is actually useful (if ever)?
Vic3Dexe
As I thought.
IMO this option is useless (0 samples = no data). Just another bug in quartus.
ShengN_Intel
Sheng
amildm
OK, so a waveform will not be drawing .... So, how to know that the condition has been met? Should I see some message in the Data Tab instead of waves?
sstrell
I've never used it, but I presume the logic analyzer would still trigger and stop running.  You just wouldn't see any data on the Data tab.
amildm
sstrell
Not sure what you mean.  It seems like this is how it would work based on what Sheng says.
