Programmable Devices
21605 Discussions
Stratix 10 SmartVID and Fixed PS
EShum
We have a board populated with Stratix 10 1SG210HU2F50E2VG.
Device programming return errors. We found out that we have SmartVID device and a Fixed Voltage Power Supply without PMbus conection to S10.
Is any chance to run SmartVID device on this board?
sstrell
I want to say that if you disable the PMBus pins (Device settings -> Device & Pin options -> Configuration -> Configuration Pin options; first 3 in the list), it would work. But I've never tried it.
EShum
PMBus pins must be enabled for bitstream generation. Otherwise Programmer returns:
Error(19192): File <filename>.sof is incomplete - Power management settings are not set up appropriately on VID part
Rahul_S_Intel1
Hi Eugene, I have send you private message pls check it. Regards, RS
