Programmable Devices
21582 Discussions
The difference between the RTL level simulation and the Gate lavel simution
HI!
Everyone!
I am using Quartus ii web 9.1 . Now There is a problem between the RTL level simulation and Gate lavel simution. I need help!
this is the code:
LIBRARY IEEE;
USE IEEE.STD_LOGIC_1164.ALL;
USE IEEE.STD_LOGIC_ARITH.ALL;
USE IEEE.STD_LOGIC_UNSIGNED.ALL;
ENTITY SKFP IS
PORT(CLK : IN STD_LOGIC;
DATA: IN STD_LOGIC_VECTOR(7 DOWNTO 0);
FP : OUT STD_LOGIC
END ENTITY SKFP;
ARCHITECTURE ART OF SKFP IS
SIGNAL FULL: STD_LOGIC;
BEGIN
PROCESS(CLK)
VARIABLE COUNT:STD_LOGIC_VECTOR(7 DOWNTO 0);
BEGIN
IF CLK'EVENT AND CLK='1' THEN
IF COUNT="11111111" THEN
COUNT:=DATA;
FULL<='1';
ELSE
COUNT:=COUNT+1;
FULL<='0';
END IF;
END IF;
END PROCESS;
PROCESS(FULL)
VARIABLE TEMP: STD_LOGIC;
BEGIN
IF FULL'EVENT AND FULL='1' THEN
TEMP:=NOT TEMP;
IF TEMP='1' THEN
FP<='1';
ELSIF TEMP='0' THEN
FP<='0';
END IF;
END IF;
END PROCESS;
END ARCHITECTURE ART;
and this is the testbench:
-- Copyright (C) 1991-2009 Altera Corporation
-- Your use of Altera Corporation's design tools, logic functions
-- and other software and tools, and its AMPP partner logic
-- functions, and any output files from any of the foregoing
-- (including device programming or simulation files), and any
-- associated documentation or information are expressly subject
-- to the terms and conditions of the Altera Program License
-- Subscription Agreement, Altera MegaCore Function License
-- Agreement, or other applicable license agreement, including,
-- without limitation, that your use is for the sole purpose of
-- programming logic devices manufactured by Altera and sold by
-- Altera or its authorized distributors. Please refer to the
-- applicable agreement for further details.
-- This file contains a Vhdl test bench template that is freely editable to
-- suit user's needs .Comments are provided in each section to help the user
-- fill out necessary details.
-- Generated on "08/22/2010 20:56:38"
-- Vhdl Test Bench template for design : SKFP
-- Simulation tool : ModelSim-Altera (VHDL)
LIBRARY ieee;
USE ieee.std_logic_1164.all;
ENTITY SKFP_vhd_tst IS
END SKFP_vhd_tst;
ARCHITECTURE SKFP_arch OF SKFP_vhd_tst IS
-- constants
-- signals
CONSTANT NEWCLK:TIME:=20 NS;
SIGNAL CLK : STD_LOGIC;
SIGNAL DATA : STD_LOGIC_VECTOR(7 DOWNTO 0);
SIGNAL FP : STD_LOGIC;
COMPONENT SKFP
PORT (
CLK : IN STD_LOGIC;
DATA : IN STD_LOGIC_VECTOR(7 DOWNTO 0);
FP : OUT STD_LOGIC
END COMPONENT;
BEGIN
i1 : SKFP
PORT MAP (
-- list connections between master ports and signals
CLK => CLK,
DATA => DATA,
FP => FP
DATA<="11111100";
init : PROCESS
-- variable declarations
BEGIN
CLK <= '0';
WAIT FOR NEWCLK/2;
CLK <= '1';
WAIT FOR NEWCLK/2;
END PROCESS init;
END SKFP_arch;
The problem is, when I use the RTL level simulation, I found It's not right.
this is the simulation printscreen.
http://images.cnblogs.com/cnblogs_com/tdyizhen1314/257630/r_mo1.bmp
But when I use the Gate level simulation, and there is no problem.
the printscreen is:
http://images.cnblogs.com/cnblogs_com/tdyizhen1314/257630/r_mo2.bmp
Now I need help, Please tell me the difference!
thanks!
It's due the differences in initialization.
In the RTL simulation, the registers are initialized to "X" or "U", since this is what the VHDL and Verilog specifications call for.
In gate level simulation, the registers are initialized to "0", since this is what the FPGA actually does.
There are two ways to handle this.
1. You can specify initial values for the registers.
2. You can add a reset signal to the module and make sure the testbench performs a reset at the beginning of the simulation.
It's normal simulation behaviour. The fp unknown state is copy from the variable temp in your design. While the gate level simulation reflects the default power on initialisation of registers, in functional simulation all signals are considered "unknown" unless you specify an initial value or use an explicite reset. This apllies at least to the variables temp and count.
rbugalho,
Thanks for your reply.
I tried before according to your method. It's OK to spcify initial values to the variables temp and count , But when I use an explicite reset(your second way) , there is still a question.
This is the code After the modification:
LIBRARY IEEE;
ENTITY SKFP IS
RST : IN STD_LOGIC; -- '0' IS VALID
FP : OUT STD_LOGIC
END ENTITY SKFP;
BEGIN
PROCESS(CLK,RST)
BEGIN
IF RST='0' THEN
FULL<='0';
ELSE
COUNT:=DATA;
FULL<='1';
ELSE
COUNT:=COUNT+1;
FULL<='0';
END IF;
END IF;
END IF;
END PROCESS;
PROCESS(FULL,RST)
BEGIN
IF RST='0' THEN
FP<='0';
ELSE
TEMP:=NOT TEMP;
IF TEMP='1' THEN
FP<='1';
ELSIF TEMP='0' THEN
FP<='0';
END IF;
END IF;
END IF;
END PROCESS;
and the testbench is:
-- Generated on "08/23/2010 12:22:05"
LIBRARY ieee;
END SKFP_vhd_tst;
-- constants
-- signals
SIGNAL RST : STD_LOGIC;
COMPONENT SKFP
PORT (
CLK : IN STD_LOGIC;
FP : OUT STD_LOGIC;
RST : IN STD_LOGIC
END COMPONENT;
BEGIN
i1 : SKFP
PORT MAP (
CLK => CLK,
DATA => DATA,
FP => FP,
RST => RST
DATA<="11111100";
RST_TEST:PROCESS
BEGIN
RST<='0';
WAIT FOR NEWCLK*5;
RST<='1';
WAIT FOR NEWCLK*20;
RST<='0';
WAIT FOR NEWCLK*3;
RST<='1';
wait for newclk*500;
END PROCESS RST_TEST;
init : PROCESS
BEGIN
CLK <= '0';
WAIT FOR NEWCLK/2;
CLK <= '1';
WAIT FOR NEWCLK/2;
END PROCESS init;
END SKFP_arch;
This is the printscreen:
http://images.cnblogs.com/cnblogs_com/tdyizhen1314/257630/r_mo3.bmp
HI!
FvM!
I tried before according to your method. It's OK to spcify initial values to the variables temp and count , But when I use an explicite reset(your second way) , there is still a question. If you want to have a look about the details please see the reply above this.
Thanks!
As I mentioned above, the variables temp and count needs initialization. Without resetting count to a defined value, your design won't work in RTL simulation.
As a side remark. Your above design is using a ripple clock (the output of one process is used as a clock in another process). This is legal VHDL, but not recommended coding style, because it creates timing issues for other signals, that are fed from the first to the second process. You don't have them now, but most likely will in a more complex design.
The problem and possible solutions ("clock enable method") have been discussed frequently in Altera forum and are covered by VHDL text books.
You are right. Maybe I didn't make the question clear before . as long as I spcify initial values to the variables temp and count . the RTL level simulation is OK .
However, AS rbugalho said, " 2. You can add a reset signal to the module and make sure the testbench performs a reset at the beginning of the simulation."
According to his method , I tried and I failed . this is the main problem which is bothering me all the time.
PS: rbugalho is the first respondent to the topic.
Yes, your design is missing a reset expression for count.
