21611 Discussions
The written code works fine, but the behavior is wrong.
OJin0
This is the code for the clock that displays minutes/seconds, and attaches the project folder.
The written code works fine, but the first digit of the second position becomes '4' upon reset.
That is, 04,05,06,07,08,09 -> 10,11,12,13,14,15,16,17,18,19 -> 20,21,22,23, was expected.
The problem works as 14,15,16,17,18,19 -> 24,25,26,27,28,29 -> 34,35....
I have a question.
There is nothing wrong with the code in the Verilog HDL editor,
Is there a place where I write code that can affect the behavior in other areas that are not visible to me?
For example,
Is there a place to write scripts?
Is there a place to write the header file?
Is it possible to insert hidden characters in the editor?
I wonder if code can be injected during compilation, etc.?
If possible, what can I do to prevent this problem?
Because, I feel like someone is tampering with my PC's Quartus from a remote location.
thank you.
Quartus 20.1.1 (image attached)
FPGA: M10, 10M08SCU169, 50MHz Clock
BOARD: QMTECH_MAX10_10M08SCU169
Coding Purpose: For Minute/Second Clock
Peripheral: 74HC595 Built-in 7-segment LED (with schematic image attached)
OJin0
The designed 4-digit 7-segments were coded for 24 hours and 60 minutes.
Currently attached coding is counted up in 1 second cycle for testing.
YEan
What do you mean by " first digit of the second position becomes '4' upon reset".
Ean
YEan
Do you have any update on your problem?
Ean
OJin0
I still don't understand.
I wrote a 4-bit counter asynchronously, and it was written to reset all 4 bits at the same time, but I don't understand whether bit0, 1, 3 become "0" and bit2 becomes "1".
After I uploaded a question to https://community.intel.com/t5/Programmable-Devices and programmed with my MAX10_10M02SCU169 board, the board is not working.
The programming seems to be complete, but the board does nothing.
Can you understand why this MAX10_10M02SCU169 board is not working?
I haven't made any progress since then. ^^
Because my MAX10_10M02SCU169 board is broken.......
I'm sorry I couldn't give you good news.
Regards.
YEan
You may use ModelSim to create testbench and observe the output signals. I have tried to create a testbench for it but there was no result. This is because the output was not the 7-segment display. I have tried to run another similar example from https://www.fpga4student.com/2017/09/seven-segment-led-display-controller-basys3-fpga.html , the output was the 7-segment display so I'm able to observe the output signals.
Ean
YEan
We do not receive any response from you to the previous question that have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
Ean
