21569 Discussions
[SignalTap] copy/paste/duplicate signals + seeing the same signal in several groups
amildm
Valued Contributor I
Hi All,
1)  Is it possible to add the same signal to SignalTap Waves Tab several times (e.g. in Questa it's possible)? Purpose - convenience in viewing the signals. The signals in my SignalTap are divided to groups, but some signals I want to see in several groups (like I could do this in Questa).
2) Is it possible to copy/paste/duplicate signals  between SignalTap instances?
Thank you!
sstrell
No, run-time triggers are standard Signal Tap instance that run when your design is running in hardware.  A power-up trigger is a child instance of a run-time trigger that lets you capture trigger events that occur after device programming but before you can open the .stp file and click "Run Analysis".  Right-click a Signal Tap instance in the .stp Instance Manager to enable it.
sstrell
1) Interesting idea, but no, there's no way to do this.
2) Again, unfortunately, no.  The only copy allowed is between a run-time trigger and it's associated power-up trigger, if you use that feature.
amildm
"The only copy allowed is between a run-time trigger" - what do you mean "run-time trigger"? signals, which are defined to be also triggers?
sstrell
SyafieqS
Dmitry,
Let me know if there is any update or concern on this
SyafieqS
I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
