Programmable Devices
21611 Discussions
Transceiver Toolkit - "locked" indicators
I'm looking for some further explanation of the LOCKED indicators in TTK.
Currently I use version 15.0 build 153 of System Console.
My questions are:
--> Is it normal for the Rx LOCKED indicators to blink green and then yellow with a properly functioning link? If so, what is this indicating? Does the TTK only say "LOCKED" when data is coming across the link, and then goes unlocked after?
I have a loopback cable that connects Tx to Rx on 4 channels. Whether or not the cable is actually connected, I see "LOCKED to ref" and "LOCKED to data" fluctuate between green and yellow within TTK. My initial interpretation was that "LOCKED to ref" would only turn green when I plugged my loopback connector in...and would stay green until the cable was disconnected. However, since TTK is saying "LOCKED to ref" without any cable on the interface, I'm a bit confused. The toggling of LOCKED also occurs whether or not I'm running something with TTK.
I put SignalTap on the "lockedtoref" and "lockedtodata" signals from the XCVR and those are also toggling unexpectedly; therefore I think it's not just the TTK GUI being flakey.
With a properly functioning link you should never loose lock to data. With a reasonable channel you could see occasional data errors, how often is an indication of the quality of the channel and the RX/TX eq settings, but not lock to data dropping out.
When locked to data is set the locked to ref is a dont care. It is possible to spuriously report lock to data briefly due to picking up noise if the inputs are floating or at a signal that is not at the correct frequency. If you have a good steady state signal on the data and lock to ref is still fluctuating then your refclk is not high quality and all bets are off.
Thanks Necare.
A further bit of clarification: I have used this link successfully to send 10GbE prior to this. So I know the link works...to some degree. I could certainly have an issue with how I've configured the PHY different from the 10GbE core I used though.
The other interesting datapoints are that BER is very bad, somewhere around 1e-2. However, the TTK Eye diagram looks OK. (I'm not an expert in what it's supposed to look like. There's an opening with ratio 40/20 if I recall correctly.)
At this point, I'm just trying to find some solid indicator of the link status, either OK or BAD.
The issue ended up being that the "pll locked" signal from my ATX PLL had been unhooked from the Reset Controller IP in Qsys. Therefore, I think the Reset Controller was constantly trying to reset things.
Now, when I open TTK, it shows a solid "locked to data" when I am running any test. (i.e. after hitting "Start")
