I'm looking for some further explanation of the LOCKED indicators in TTK.
Currently I use version 15.0 build 153 of System Console. My questions are: --> Is it normal for the Rx LOCKED indicators to blink green and then yellow with a properly functioning link? If so, what is this indicating? Does the TTK only say "LOCKED" when data is coming across the link, and then goes unlocked after? I have a loopback cable that connects Tx to Rx on 4 channels. Whether or not the cable is actually connected, I see "LOCKED to ref" and "LOCKED to data" fluctuate between green and yellow within TTK. My initial interpretation was that "LOCKED to ref" would only turn green when I plugged my loopback connector in...and would stay green until the cable was disconnected. However, since TTK is saying "LOCKED to ref" without any cable on the interface, I'm a bit confused. The toggling of LOCKED also occurs whether or not I'm running something with TTK. I put SignalTap on the "lockedtoref" and "lockedtodata" signals from the XCVR and those are also toggling unexpectedly; therefore I think it's not just the TTK GUI being flakey.Link Copied
With a properly functioning link you should never loose lock to data. With a reasonable channel you could see occasional data errors, how often is an indication of the quality of the channel and the RX/TX eq settings, but not lock to data dropping out.
When locked to data is set the locked to ref is a dont care. It is possible to spuriously report lock to data briefly due to picking up noise if the inputs are floating or at a signal that is not at the correct frequency. If you have a good steady state signal on the data and lock to ref is still fluctuating then your refclk is not high quality and all bets are off.- Mark as New
Thanks Necare.
A further bit of clarification: I have used this link successfully to send 10GbE prior to this. So I know the link works...to some degree. I could certainly have an issue with how I've configured the PHY different from the 10GbE core I used though. The other interesting datapoints are that BER is very bad, somewhere around 1e-2. However, the TTK Eye diagram looks OK. (I'm not an expert in what it's supposed to look like. There's an opening with ratio 40/20 if I recall correctly.) At this point, I'm just trying to find some solid indicator of the link status, either OK or BAD.- Mark as New
The issue ended up being that the "pll locked" signal from my ATX PLL had been unhooked from the Reset Controller IP in Qsys. Therefore, I think the Reset Controller was constantly trying to reset things.
Now, when I open TTK, it shows a solid "locked to data" when I am running any test. (i.e. after hitting "Start")
