USB Blaster help
AWann1
I have installed the stand alone Quartus Programmer 21.1.1.850.
I installed the USB Blaster drivers. The windows laptop sees the USB Blaster when it's connected.
However, the programmer software does not see the USB Blaster. I cannot select it when trying to assign hardware, it does not even appear as an option.
Has anyone seen this before?
AWann1
Apparently Intel's drivers for the Byte Blaster are not signed in Windows 10. So Windows doesn't allow them to work.
Here's what I found to get it function:
1 - Go to windows 10 settings and search for "advanced startup options"
2 - Under Advanced startup, hit "Restart now"
3 - After a moment, you'll get a "choose an option" screen - choose "Troubleshoot", then "Advanced options", then "Startup Settings"
4 - You'll get a screen telling you what you will be able to change and a single "Restart" button - press it.
5 - You'll be given a menu of options, number 7 disables driver signature enforcement
6 - When the PC restarts, use Device manager to update the drivers, point to the "drivers" folder in your quartus install directory
7 - When you've finished, restart normally to re-enable signature enforcement
ak6dn
Valued Contributor III
What version of Windows software is your laptop running?
AWann1
Fakhrul
Hi AWann1,
You may give it a try the steps mentioned in the following KDB:
Why is Altera® USB Blaster not detected by Quartus® Programmer when it is recognized correctly in Device Manager?
Hope this could solve your issue.
Fakhrul
AWann1
Thank you for this suggestion!
Unfortunately, it did not seem to make any difference. The USB Blaster is still not seen by the Programmer window.
ak6dn
I am using Windows 10 Pro 64b 21H2 and have no Altera USB driver issues.
I have two separate USB pods (a TerAsic Blaster, and a Waveshare USB Blaster from Amazon) and a DE1 board with embedded interface.
They all work fine, and I see 3x USB interfaces installed and available.
I use either Quartus 13.0sp1, 16.0, or 21.1 depending on what I am doing.
Here is what Windows 10 shows about my Altera driver:
AWann1
Fakhrul
Hi AWann1,
I’m glad that you find the solution, I now transition this thread to community support.
This will be a good reference for the others
