Programmable Devices
21615 Discussions
.V files not showing up in project navigator hierarchy tab
msager
In my project only the top level .bdf file is showing up in the project navigator hierarchy tab. For some reason the .v files are not showing. I am attaching a picture of the .bdf file. I saved all the .v files and they are all in the files tab and also within the .bdf file. I just don't know why they're not showing up.
Please help!
msager
The compilation doesn't finish I let it run for a long time. I am not sure what the issue was but I made a new project and re-did everything and it worked.
sstrell
That's not how the Hierarchy tab works.  The Hierarchy tab displays your project hierarchy after you've performed at least Analysis & Elaboration from the Processing menu, which checks your design files for errors and builds the hierarchy based on your connections and instantiations.  It looks like you have not run Analysis & Elaboration or full synthesis yet in this design.
KennyTan_Altera
Can you check if after you run the elaboration still facing the problem? If yes, can you attached your design to us?
KennyTan_Altera
Not sure if you have update on the request above?
msager
When I try to "Start Compilation"  it stops at "Analysis and Synthesis" phase. I also don't get any errors just warnings.
sstrell
That screenshot shows that the compiler is still running.  You have to wait for it to finish.
And you should check the warnings against your design to see if they are acceptable or if you need to fix something.
KennyTan_Altera
Sstrel is right, you will need to make sure the compilation is finished before can see the hierarchy. Do let us know if you are facing any issue.
msager
KennyTan_Altera
It is great to hear that it was finally working, sometime we will have to refresh the project to make it work. Any further question? if no, we shall close this thread.
KennyTan_Altera
Since this thread have mark with solution accepted, we shall close this thread.
