Programmable Devices
21190 Discussions
VHDl spi adc example
Tex
i'm learning about spi with altera max 10 using 24 bit adc..
previously i got few examples from few people of the forum but they are very complex to learn..
also please suggest me any course on vhdl to learn..
@ShengN_Intel
@FvM
please try to help me..
Tex
ShengN_Intel
Hi Tex,
Max 10 ADC are line-in ADC. Usually Modular ADC Core IP is used for that. Check these two links http://gogofpga.blog.fc2.com/blog-entry-182.html and https://www.youtube.com/watch?v=0oO1RFa-4Xk&t=1s
The SPI RTL design example can be found had been shared to you before. Can't find any VHDL one. Btw, the design store example design https://www.intel.com/content/www/us/en/design-example/715016/max-10-serial-peripheral-interface-master-an-485.html I had been tested on DE-10 Standard (Cyclone V) ADC since Max 10 ADC are line-in ADC. Check the attached design folder and STP waveform. The function as below:
Control Register Write: CS high, WR high
Transmit through MOSI: CS high, WR high, addr "10"
Status Register Read: CS high, RD high, addr "01"
Received (MISO) to data_bus: CS high, RD high, addr "11"
Sheng
ShengN_Intel
Hi Tex,
FYI that currently we don't have exact example design for 24-bit adc as Intel's board mostly in-built with 12-bit adc.
May be can try to get the example design from the vendor of 24-bit adc.
Sheng
Tex
hi sheng,
Okay, apart from 24-bit or anything i want to learn spi communication in VHDL using any adc..
please share any tutorials or codes to learn with altera max 10..
Tex
ShengN_Intel
Hi Tex,
Sheng
Tex
Thank you sheng this helped me alot..
