21584 Diskussionen
What is meant by "under bias" in MAX V absolute maximum ratings
SZack
Partner
958Aufrufe
What does Altera mean by “under bias” in their maximum ratings table (Table 3-1 from the datasheet -> see attachment)? It is from the Max V DC and switching characteristics.
Note 3 says to refer to Table 3-2 in the datasheet but there is no reference to biasing in Table 3-2
2 Antworten
ak6dn
Geschätzter Beitragender III
704Aufrufe
"Under bias" in this context simply means that power is applied to the supply pins that meets the min/max specifications. Ie, VCCint and VCCio are valid as per table 3-2.
Table 3-1 indicates that the highest temperature permitted with no bias (unpowered) is 150'C, whereas it is 135'C when the device is powered.
SZack
Partner
704Aufrufe
Thanks for the quick response
Steve
Antworten
