Programmable Devices
21602 Discussions
about component
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_unsigned.all;
entity mand2 is
port(
a,b:in std_logic;
c:out std_logic);
end mand2;
architecture bb of mand2 is
begin
c<=a and b;
end bb;
use work.mand2.all;
library ieee;
use ieee.std_logic_1164;
entity p60 is
port(x,y:in std_logic;
z:out std_logic);
end p60;
architecture b of p60 is
component mand2
port(a,b:in std_logic;
c:out std_logic);
end component;
begin
mand2 port map(a=>x,b=>y,c=>z);
end b;
Error (10500): VHDL syntax error at p60.vhd(14) near text "port"; expecting "(", or "'", or "."
i really can't understand that error.
help&#65292;i have the vhdl term exam 1 hour later.thanks for everyone's attention.
All the questions you have easily find an answer in any VHDL book... to instantiate a component the syntax is:
Label: componentName generic map (...) port map (...);
thank you.when i add the Label,quartus ii reports error again.
Error (10800): VHDL error at p60.vhd(1): selected name in use clause is not an expanded name.
but i've already add mand2.vhd to the current project.
use work.mand2.all;
mand2 is not a package, so you cannot "use" like that. You dont need this line.
Thank you.
