Programmable Devices
21615 Discussions
clock generation from cyclone3
hi,
i want to generate 216Hz clock from cyclone3 pll mega function with 8.192MHz as pll input , but pll is not supporting.
if i generated using logic elements is there any problem (with suitable i/p clock)?
is it possible to access all the 5 outputs of pll?
i hope u can help
thanks
I dont think you can get a 216MHz clock out of a 8.192 MHz input at all. At least not exactly. If you want to get close to it, you can try to cascade 2 PLLs, but not sure about JItter and clock quality.
Lokla
hi,
please tell how to cascade plls in cyclone3
regards
krishnam raju
Use the output clock signal of one PLL as input to the second PLL.
Lokla
hi..please tell how to write
vhdl code for frequency divider with 50% duty cycle.
regards
Is this question somehow related to the original post?
In any case, you can use a counter for that.
