21611 Discussions
configurate altlvds_rx input port rx_syncclock for cyclone iv
XQSHEN
EP4CE22F17C7
The ip user guide, we can see input port rx_syncclock for this ip altlvds_rx.
But I can not see anywhere from quartus prime 18.0.
AminT_Intel
Can you share which part of the document do you mean?
Thank you.
XQSHEN
XQSHEN
I don't see anywhere from below window to configure  rx_syncclock or rx_cloreclk.
So the code generated doesn't have this port for me to do anything.
XQSHEN
I suppose there should be somewhere can pull out rx_syncclock or rx_cloreclk.
Then we can use it my project and connect to external pll output.
Unfortunately, I don't find it.  I need this help.
XQSHEN
How to enable below rx_coreclk?
AminT_Intel
Which version of Quartus and device do you use?
Thank you.
XIAOQ
EP4CE22F17C7
quartus prime 18.0.
AminT_Intel
This option is enabled when the LVDS is implemented in logic. When you turn on this option, it adds an input port, which when asserted performs an asynchronous reset of all the logic in the ALTLVDS_RX IP core excluding the PLL.
Thank you.
AminT_Intel
 We do not receive any response from you to the previous question/reply/answer that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
