21489 Discussions
on chip memory does'nt work with 150 MHz on Cyclone V E development kit
töz00
hello dear Intel,
I am using Cyclone V E development kit. I set up a simple nios system(clock-pll-nios II processor- onchip memory-jtag uart) . This system runs with 50 MHz clock frequency. When i raise clock frequency to 150 MHz , system gives me an error (processor pausing and reset failed ). i can work with sdram at 150 MHz but . couldn't run with on chip memory. Does anybody know why this happens?
sstrell
It would be necessary to set up timing constraints and perform a timing analysis to verify where the failure is occurring.
Also, which version of the Nios II are you using: e (no license needed) or f?
#iwork4intel
EricMunYew_C_Intel
Hi, Steven
You may need to run timing analysis in Quartus, make sure there is no timing errors.
For example,
create_clock -period "150 MHz" -name {clk} {clk}
derive_pll_clocks
The timing report will tell you the max. frequency you can run, or you have to do place and route to improve timing.
Eric
EricMunYew_C_Intel
Hi, Steven
Can we close this case ?
Eric
töz00
sorry for answer late. Yes I solved my problem. You can close this case.
Thank you for your support!
EricMunYew_C_Intel
