Programmable Devices
21615 Discussions
problems with pin assignments
Using the assigments file, I'm working in a simple design which contains NIOS+SRAM+Flash+UART.
I've assigned to TX a signal called HC_UART_TXD, When I run the project I can see message "Hello World" in hyperterminal.
The problem is when I try to configure RX with a signal called HC_UART_RXD, because the FPGA port of this signal is share with another signal called ~ALTERA_nCEO~. And I don't know how I can remove this error.
Error: Can't place pins assigned to pin location Pin_E18 (IOPAD_X53_Y21_N14)
Info: Pin HC_UART_RXD is assigned to pin location Pin_E18 (IOPAD_X53_Y21_N14)
Info: Pin ~ALTERA_nCEO~ is assigned to pin location Pin_E18 (IOPAD_X53_Y21_N14)
Go to Device and Pin Options and set nCEO to be used as regular IO after config.
TO_BE_DONE
Have you also set those pins to used as regular IO after config? Most of them come under Other Active Parallel pins
I've done this,
nCEO --> from programming pin --> to regular I/O
other active parallel pins --> from programming pin --> to regular I/O
data[7..2] --> from input tristated --> to regular I/O
Compilation was successful
compilation was successful, thanks a lot!!!!!!
best regards
