I've lost my HDD after installing rapid storage technology. It's using it as recovery drive. how should I fix it?
my system is acer predator G9-793
tnx,
Why did you install RST? Do you have RAID or Optane? If not, you do not need RST.
Did you have a backup?
Doc
Dear sir,
thank you for your feedback.
Actually, I just changed my windows and after that I downloaded my computer driver's from acer website and I am not familiar with RAID or Optane.I just want to have access to my HDD again and no I don't have any backups but being able to use it again is priority. Is there any way?
tnx, (sorry for bad english)
Does anyone Know what should I do?
Hello LSea0,
You might try the following:
Try to enter to Intel® Rapid Storage Technology (Intel® RST) option ROM
You can access it by pressing Ctrl + i when the computer when your computer is posting once you get there:
- Mark the drive as "Non-RAID".
- Reboot your system.
- Make sure you have a back up since your information can be lost.
Note: if the key combination Ctrl + i does not work to access Intel® Rapid Storage Technology (Intel® RST) option ROM you might need to contact the system manufacturer to get the appropriate steps to access it.
Adrian M.
Hello LSea0,
Let me know if you need more assistance.
Adrian M.
Hi sir,
I tried to access the option rom but ctrl+i didn't work for me.
Hello LSea0,
Thank you for your input.
I will recommend you to contact the system manufacturer of your computer since this key combination to access the Intel® Rapid Storage Technology (Intel® RST) option ROM can be different/customized depending on the manufacturer, once you get access to it followed the steps suggested.
Hope this helps.
Adrian M.
