Rapid Storage Technology
Intel® RST, RAID
2189 토론
Intel Rapid Storage Technology
직원
44,166 조회수
I have a home-built system running the DH77EB board, Ivy Bridge i7, 8GB RAM, WIndows 8 Release Preview, Radeon HD7870 and a Samsung 830SSD.
I saw that the most recent 11.6 version of the Intel Rapid Storage Technology driver now lists Windows 8 compatibility, the prior 11.4 version worked on Windows 8 but did not list Windows 8 compatibility. I went ahead and installed 11.6, but it does not appear to start - the icon in the system tray says Intel RST service is not running, and when I click on it to launch the app, nothing happens. I checked the error log and this is what I see:
Log Name: Application
Source: Application Error
Date: 9/23/2012 3:11:55 AM
Event ID: 1000
Task Category: (100)
Level: Error
Keywords: Classic
User: N/A
Computer: XYZ
Description:
Faulting application name: IAStorUI.exe, version: 11.6.0.1030, time stamp: 0x5042b0f9
Faulting module name: ISDI2.dll, version: 11.6.0.1030, time stamp: 0x5042b0b6
Exception code: 0xc0000417
Fault offset: 0x0004d11f
Faulting process id: 0x1ad0
Faulting application start time: 0x01cd995ab619ce9a
Faulting application path: C:\Program Files (x86)\Intel\Intel(R) Rapid Storage Technology\IAStorUI.exe
Faulting module path: C:\Program Files (x86)\Intel\Intel(R) Rapid Storage Technology\ISDI2.dll
Report Id: f412be45-054d-11e2-9b7d-000272da1ace
Faulting package full name:
Faulting package-relative application ID:
Event Xml:
Next, I try to manually start the service using the Task manager, but the service starts for only a millisecond before stopping again. Checking the Event Log, and I just see simply "The Intel(R) Rapid Storage Technology service terminated unexpectedly. It has done this 2 time(s)."
Has anyone else had this issue with 11.6?
0 포인트
1 솔루션
직원
34,574 조회수
Intel Rapid Storage Technology 12.0.0.1083 at station drivers does seem to fix the problem, at least for me it seems to be working...
원본 게시물의 솔루션 보기
0 포인트
51 응답
MSmit17
초보자
4,945 조회수
My marvells have always been disabled on my P8z68 mobo, issue is still there.
0 포인트
Silvia_L_Intel1
4,945 조회수
Morrissey Smith, there is a new Intel® Rapid Storage Technology version that you may want to try, however I would recommend you to check if there is a new BIOS available for your ASUS motherboard. Download Center
0 포인트
MSmit17
초보자
4,945 조회수
@ sylvia_intel No, still the assertion error since long long time ago.....only IRST 11.2 works for me. No Bios update either, last one for my mobo conteined RAID 11.2 precisely.
0 포인트
RDunz
초급자
4,945 조회수
MSI X58 Platinum SLI motherboard
i7 960
Intel Rapid Storage Technology 12.8.0.1016
Resolution:
Uninstall KB2670838, the "evil update".
It is sneaky, and will reinstall with IE10 (I think) and IE11 for sure.
Many difficulties reported with it, ask Google.
Test:
Discovered the GUI wouldn't run, found that the evil update had been installed again, uninstalled it, reboot, and GUI works.
Good luck.
Errors:
Source: Application Error Faulting application name: IAStorUI.exe, version: 12.8.0.1016, time stamp: 0x51fb0c6d
Faulting module name: KERNELBASE.dll, version: 6.1.7601.18229, time stamp: 0x51fb1116
Exception code: 0xe0434352
Fault offset: 0x0000c41f
Faulting process id: 0x11ac
Faulting application start time: 0x01cf1430d11fb0b2
Faulting application path: C:\Program Files\Intel\Intel(R) Rapid Storage Technology\IAStorUI.exe
Faulting module path: C:\Windows\syswow64\KERNELBASE.dll
Report Id: 0fbd8b25-8024-11e3-b1c0-0024211c6a96
Source: .net runtime Application: IAStorDataMgrSvc.exe
Framework Version: v4.0.30319
Description: The process was terminated due to an unhandled exception.
Exception Info: System.NullReferenceException
Stack:
at IAStorUtil.SystemDataModelListener.ProcessSystemDataModelChanges()
at IAStorUtil.SystemDataModelListener.LoadSavedSystemState()
at IAStorDataMgr.EventRelay.b__0(System.Object)
at System.Threading.QueueUserWorkItemCallback.WaitCallback_Context(System.Object)
at System.Threading.ExecutionContext.RunInternal(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean)
at System.Threading.ExecutionContext.Run(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean)
at System.Threading.QueueUserWorkItemCallback.System.Threading.IThreadPoolWorkItem.ExecuteWorkItem()
at System.Threading.ThreadPoolWorkQueue.Dispatch()
at System.Threading._ThreadPoolWaitCallback.PerformWaitCallback()
0 포인트
MSmit17
초보자
4,945 조회수
Maybe i shouldn't have posted on this thread cause the issue posted here i think is different from mine, i have a GUI Assertion error on Windows 7 64 bits, only IRST 11.2 has worked for me since year 2011.
i think the evil updated fix worked for you cause we have different problems here, if you want to check the KB2670838 update was released on February 26, 2013
http://support.microsoft.com/kb/2670838 http://support.microsoft.com/kb/2670838
The assertion issue is older (2011), even this thread is older than that microsoft patch (2012).
0 포인트
MNaru
초급자
4,945 조회수
Hello
Why is caching very slow on windows 10 compared to windows 8 ?
will update drivers or utilities RST ?
0 포인트
IUman
명예로운 기여자 II
4,945 조회수
harbor make sure you have the latest chipset driver installed in your system, management engine driver, also the latest BIOS version.
0 포인트
tuser22
초급자
4,945 조회수
Since I had to read most of this thread to find the relevant info let me repeat it at the end
I just discovered the same old problem again on my older box running for years ?!?!
(I forgot that I added a iscsi drive on my NAS to the system. That safely killed the Intel Service without any usable error message!!!!)
MY WORKING SOLUTION:
DISABLE the microsoft iScsi driver so the intel RST service is running again.
Mostly you have to reboot for this
No need to mess around with the Marvel Drivers (only DVD connected as HD connected there was causing problems with the Intel Driver anyway)
mbd: GA X79-UD3
cpu: i7-3930K
gra: GTX680
ram: 4 x4GB
sys: Windows 7 x64 (SP1 build 7601) on Samsung SSD840
sto: Intel RST RAID5 on 4 x WD RED 2T
I would expect such a predictable mistake could be fixed sometime but it does not look like it!
Upgrading my Intel RST driver failed. I am running the Version 11.6.0.1030
0 포인트
IUman
명예로운 기여자 II
4,945 조회수
If you are getting an error message on Intel RST that says "Intel RST service not running" the steps on the following link should fix the issue http://www.intel.com/content/www/us/en/support/boards-and-kits/000005794.html http://www.intel.com/content/www/us/en/support/boards-and-kits/000005794.html
The link pretty much applies to every single Intel RST version and any operating system. This is a setting needs to be changed in Windows* services. You can open Windows* services by pressing WinLogo key + r, type in services.msc, then press Enter. Look for the Intel Rapid Storage Technology service, double-click on it, and then follow steps on the website.
0 포인트
ssean3
초급자
4,945 조회수
This didn't work for me.
Anyone have an update to this issue? Seems pretty widespread.
THX
0 포인트
응답
