Rapid Storage Technology
Intel® RST, RAID
2190 Discussions
RST Management will not open if a VHD is mounted Error Code 0xA0080000 and 0xA00906B3
PaulN
Asrock z790 RS Pro + 13th Gen i3 13100
2x WD NVME in raid 1
Raid Drivers tested (SetupRST) = 18.7.6.1010 / 19.5.7.1058 (From Asrock) / 19.5.8.1059.2
Windows 11 pro 24H2
Memory = Crucial (64GB)
Intel Rapid Storage Technology Application - opens fine and works with no VHD (from a file) mounted.
As soon as a VHD is mounted the App fails to open with either 0xA0080000 or 0xA00906B3 errors ( tested with VHD file on raid and none raid sata ACHI drive )
I have tried uninstall and reinstall and the following links
https://www.intel.com/content/www/us/en/support/articles/000056936/memory-and-storage/intel-optane-memory.html
PaulN
Installed the drivers 20.2.1.1016 and reinstalled the management app.
It seems to only pick up one of my SATA drives
I did have an idea to remove all intel programs ( BCUninstaller) and drivers (Driver Store Explorer)
Not my greatest idea as it caused W11 not to start "inaccessible boot device" good job I have system restore turned on!
It reverted back to old driver and all 4 SATA drives were shown.
Reinstalled  20.2.1.1016 and reinstalled the management app.
After mounting the VHD and pressing the rescan I get an error/crash
"Faulting application name: RstMwService.exe, version: 20.2.1.1016, time stamp: 0x671ba832
Faulting module name: RstMwService.exe, version: 20.2.1.1016, time stamp: 0x671ba832
Exception code: 0xc0000005
Fault offset: 0x00000000000c1d63
Faulting process id: 0x1B88
Faulting application start time: 0x1DC2B9ED31AA7AB
Faulting application path: C:\WINDOWS\System32\DriverStore\FileRepository\iastorvd.inf_amd64_da06297c4b8e9167\RstMwService.exe
Faulting module path: C:\WINDOWS\System32\DriverStore\FileRepository\iastorvd.inf_amd64_da06297c4b8e9167\RstMwService.exe
Report Id: e92ef569-ccfe-407b-b571-eee27bc5d960
Faulting package full name:
Faulting package-relative application ID:"
Restarting the RstMwService.exe fails
PaulN
As an after thought - Would it be possible for the management app to ignore drives that are not RAID. In my case that would be the 4 AHCI drives and any VHDs ?
Paul
DeancR_Intel
Hi Paul,
Thank you for contacting Intel Customer Support regarding the Intel Rapid Storage Technology (RST) issues you're experiencing with driver version 20.2.1.1016. I understand how frustrating it must be to deal with the RST Management app only detecting one SATA drive and the RstMwService.exe crashes when mounting VHDs and using the rescan function.
I can see that you've done extensive troubleshooting, including a complete removal of Intel programs and drivers (which unfortunately caused the boot issue), and you've provided detailed error information showing the RstMwService.exe crash with exception code 0xc0000005.
Current Issues Identified:
  1. Drive Detection: RST Management app only shows 1 of 4 SATA drives with driver 20.2.1.1016
  2. Service Crash: RstMwService.exe crashes when mounting VHD and pressing rescan
  3. Service Recovery: RstMwService.exe fails to restart after crash
  4. Driver Regression: Older driver showed all 4 SATA drives correctly
Your idea about the management app ignoring non-RAID drives (AHCI drives and VHDs) is interesting from a user experience perspective. However, the current behavior where RST interacts with all storage devices is by design for comprehensive storage management.
Based on your system configuration and the specific issues you're experiencing, I recommend trying the latest RST driver package designed for your platform. The latest version available is 20.2.1.1016.4, which includes important fixes that may resolve your drive detection and VHD interaction issues:
Intel® Rapid Storage Technology Driver Installation Software (Version 20.2.1.1016.4) Download Link: https://www.intel.com/content/www/us/en/download/849936/intel-rapid-storage-technology-driver-insta…
Installation Steps:
  1. Uninstall current RST software completely through Windows Settings
  2. Restart your system
  3. Download and install RST version 20.2.1.1016.4 from the link above
  4. Restart again after installation
  5. Test drive detection and VHD functionality
Why This May Help:
  • Version 20.2.1.1016.4 includes fixes for the RstMwService.exe crash you're experiencing
  • Updated storage enumeration that should properly detect all your SATA drives
  • Improved VHD handling and rescan functionality
  • Addresses the specific issues you encountered with version 20.2.1.1016
After installation, please test:
  1. Drive Detection: Verify all 4 SATA drives appear in RST Management app
  2. VHD Mounting: Mount your VHD without crashes
  3. Rescan Function: Test rescan button without RstMwService.exe crashes
  4. Service Stability: Monitor RstMwService.exe for stability
If you continue to experience the same issues after installing RST version 20.2.1.1016.4, please provide the new error details, and we can explore additional solutions or investigate this as a potential compatibility issue.
Your detailed documentation of the problem has been very helpful for understanding the issue.
Dean R.
PaulN
Thank you for your continued help.
When I install Version 20.2.1.1016.4 it shows as 20.2.1.1016  ( Have tried twice and re-downloaded for 2nd attempt )
It acts the same as before 1 drive shown , rescan crashes app.
 Paul
DeancR_Intel
Hi Paul,
Thank you for testing the Intel RST Driver Installation Software version 20.2.1.1016.4 and for providing the screenshot showing the installation results. I appreciate you taking the time to download and install it twice to ensure the process was completed properly.
I can see from your screenshot that despite downloading version 20.2.1.1016.4, the system is still showing version 20.2.1.1016, and unfortunately, the same issues persist:
  • Only 1 of 4 SATA drives detected in RST Management app
  • RstMwService.exe crashes when mounting VHD and using rescan function
  • No improvement in drive detection or service stability
Current Status:
  • Driver regression confirmed (older driver detected all drives correctly)
  • Latest available RST version fails to resolve the issues
  • RstMwService.exe crash with exception code 0xc0000005 persists
  • VHD interaction continues to cause service failures
Given that the latest RST driver version has not resolved your drive detection and VHD interaction issues, I will be checking this matter internally for further investigation. The persistent problems you're experiencing with:
  • Drive enumeration (only showing 1 of 4 SATA drives)
  • RstMwService.exe crashes during VHD operations
  • Service recovery failures require deeper technical analysis beyond standard driver updates.
I will get back to you once I have more information from our internal investigation regarding potential solutions or alternative approaches for your RST configuration issues.
Your detailed documentation and testing efforts have been invaluable for understanding the scope of these problems with the current RST driver version.
Thank you for your patience as we work to resolve these RST functionality issues.
Dean R.
DeancR_Intel
Hi Paul,
Thank you for your detailed report regarding the Intel Rapid Storage Technology (RST) Management application crashes you're experiencing with Virtual Hard Disk (VHD) files on Windows 11 Pro 24H2.
I've thoroughly reviewed your comprehensive troubleshooting efforts, including the clean driver reinstallations, service management testing, and system configuration analysis. Your systematic approach to isolating this issue with RST versions 18.7.6.1010, 19.5.7.1058, and 19.5.8.1059.2 has been extremely valuable.
Intel has recently released a new version of RST that may resolve the VHD interaction issues you're experiencing:
Intel Rapid Storage Technology Driver Version: 20.2.6.1025.2 Download Link: https://www.intel.com/content/www/us/en/download/849936/intel-rapid-storage-technology-driver-installation-software-with-intel-optane-memory-12th-to-15th-gen-platforms.html
Installation Instructions:
  1. Uninstall your current RST driver version 19.5.8.1059.2
  3. Install the new RST driver version 20.2.6.1025.2
Testing Request: After installing version 20.2.6.1025.2, please test the following scenarios that previously caused crashes:
  1. VHD Mounting: Mount your 8GB BitLocker encrypted VHD using both Disk Manager and Explorer right-click methods
  2. RST App Interaction: Launch RST Management application with VHD mounted
  3. Rescan Function: Test the Rescan button that previously triggered consistent crashes with error codes 0xA0080000 and 0xA00906B3
  4. Service Stability: Monitor Intel Storage Middleware Service (RstMwService.exe) behavior during VHD operations
This newer RST version includes updates specifically for Windows 11 24H2 compatibility and may resolve the service termination issues you've been experiencing when the RST application interacts with mounted VHDs.
Dean R.
PaulN
Sadly I get the same error in both right click and Disk Manager.
As you can see still only one drive.
Also (May not be linked) In performance tab
Link power and Link rate are disabled.
In Bios PCIe Native Control and SATA Aggressive Link Power Management are "Enabled"
Paul
DeancR_Intel
Hi Paul,
Thank you for testing the Intel RST Driver version 20.2.6.1025.2 and providing the detailed screenshots. I can see that unfortunately; the same issues persist even with this latest version:
  • Only 1 of 4 SATA drives still showing in RST Management app
  • RstMwService.exe continues to crash when mounting VHDs (both right-click and Disk Manager methods)
  • Link Power and Link Rate options remain disabled in the Performance tab
I appreciate you also noting the BIOS settings where PCIe Native Control and SATA Aggressive Link Power Management are enabled, as this could potentially be related to the power management issues you're observing.
Current Status Summary:
  • Tested RST versions: 18.7.6.1010, 19.5.7.1058, 19.5.8.1059.2, 20.2.1.1016, 20.2.1.1016.4, and now 20.2.6.1025.2
  • All recent versions show the same regression (only 1 drive detected vs. older versions showing all 4)
  • VHD interaction consistently crashes RstMwService.exe across all tested versions
  • Power management features disabled in RST interface
Given that multiple RST driver versions, including the very latest release, have not resolved these persistent issues, I will be checking this issue for specialized investigation. The consistent drive detection regression and VHD interaction crashes across multiple driver versions indicate this requires deeper technical analysis beyond standard troubleshooting.
I will check this matter internally and get back to you with additional solutions or alternative approaches for your RST configuration.
Thank you for your patience and thorough testing throughout this process.
Dean R.
