Rapid Storage Technology
Intel® RST, RAID
2189 Discussions
Windows 10-update version 1903 can't be installed due to Intel RST Driver?
ME0001
I'm getting an error message saying Windows 10-update version 1903 can't be installed because of an issue with my Intel RST Driver.
Saw in other recent topics that I might have to uninstall the driver (package?) from either 'device manager' (under storage controllers) or 'apps & features' but Intel RST isn't listed under either of those.
Windows itself tells me I can fix the problem by installing an update from here https://downloadcenter.intel.com/download/28656/Intel-Rapid-Storage-Technology-Intel-RST-User-Interface-and-Driver
But I don't know which package to install (SetupRST, SetupOptaneMemory or f6flpy-x64.zip), nor which file to execute if the one I need is a .zip package with multiple .exe files.
Can anyone help?
David_V_Intel
Hello ME0001,
Thank you for posting on the Intel ® communities.
Let's try following the steps below:
1 - Please update the system to Intel® RST driver version 15.9.6.1044.
2 - Manually delete the iastora folder in C:\Windows\System32\drivers\iaStorA.sys
3 - Restart the installation process for the Update.
*NOTE: Please download the .exe file from the link you provided and proceed with the update as stated in Step 1.
Let me know if those steps allow you to finish the Windows Update.
David V
A Contingent Worker at Intel
jhuar2
I have exactly the same problem and tried the following without success after several blocked update processes
  1. re install a completely new version of windows (factory installation on asus laptop)
  2. install the latest version of your RST driver Version: 17.5.1.1021 (Latest) Date: 7/10/2019 (version 15 is marked as out of date....on your site)
  3. let windows make the adequate cumulative updates
  4. let windows start update to 1903
The result is negative (same error message as mentioned above)....
What do you recommend ? Should I uninstall version 17.5 and install version 15.9.6.1044 instead ? Your help would be appreciated
Thanks for your cooperation
LeonWaksman
Hi @jhuar2​
Your problem is similar but may be not the same. Please open a new thread of yours and you will get answer to your question. In your thread, please explain: Was the RST driver part of Asus installation? If yes, why? Are you have Optane Memory module installed in your laptop? Or, you have drives configured to RAID? What is you laptop model?
Leon
David_V_Intel
Hello ME0001,
Were you able to check my previous post?
Please let me know if you need more assistance.
David V
David_V_Intel
Hello ME0001,
Please contact us if you have any additional questions.
David V
