Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage, and Intel® Xeon® Processors
4544 Discussions
совместимость модуля памяти (R2208WFTZSR/xeon 6130/64*4
РГайн
Добрый день
Имеем в наличии серверную платформу Intel Original R2208WFTZSR с установленным процессором Xeon Gold 6130. При первой попытке установить память MTA36ASF8G72PZ-3G2E1 64Gb DIMM ECC Reg PC4-25600 CL22 3200MHz получил ошибку fatal error: system encountered a stopper error. Поставил другу память, прошил биос материнской платы до последней имеющейся версии. Теперь при установке MTA36ASF8G72PZ-3G2E1 уже получаю ошибку fatal error: (memory) no memory detected. Должна ли данная память вообще работать в данной конфигурации? Спасибо всем кто откликнется...
JoseH_Intel
Hello РГайн,
Thank you for joining the Intel community
Based on the Intel serverconfigurator.intel.com tool, this exact memory you are using is not validated for your system. The one currently validated is:
MTA36ASF8G72PZ-2G9E1 64GB (1x64GB) RDIMM, DDR4, 2 Rank, 2933MHz
For more info you can check https://serverconfigurator.intel.com/exodus/page?eventType=11&targetPageId=120203103&defaultFlag=1 under the S2600WFT board
Hope this helps
Jose A.
For firmware updates and troubleshooting tips, visit:
https://intel.com/support/serverbios
JoseH_Intel
Hello РГайн,
I am just following up to double-check if you found the provided information useful. If you have further questions please don't hesitate to ask. If you consider the issue to be completed please let us know so we can proceed to mark this ticket as closed. I will try to reach you back on next Monday 28th. After that the thread will be archived automatically.
Jose A.
JoseH_Intel
Hello РГайн,
We will proceed to mark this thread as resolved. If you have further issues or questions just go ahead and submit a new topic.
Jose A.
