Server Products
4909 Discussions
Does Eagle Stream cscript rev2218-6000-Build1078 support E3 processor?
Max_J_
Hi All,
As title, I initial cscritp rev2218-6000-build1078 with E3 CPU Q16W and get below infomation. look like rev2218 cannot idientify E3 cpu。
Does rev2218 support E3 CPU or Intel has the newer version?
Thanks a lot
SergioS_Intel
Hello Max_J_,
Thank you for contacting Intel Customer Support.
To better assist you, can you please confirm the model and the manufacturer of the system that you are planning to install your processor?
Can you please provide us the model of your Intel(R) processor?
We will be looking forward to your response.
Sergio S.
SergioS_Intel
Hello Max_J_,
We are following this thread and would like to know if you need more assistance.
Sergio S.
Max_J_
So sorry, we finally found it is single board issue, after change another MLB, this issue doesn't occur .
Thanks for your reply
JosueO_Intel
Hello Max_J_,
Thank you for the information provided, we are happy to hear that the issue is solved and everything is working fine.
Josue O.
