Server Products
4875 Discussions
Quadro NVS 440 with Intel Motherboard S1200V3RPS showing garbage during BIOS screen
achau10
Helllo, THis is my first post on the forum. Please help me with the following issue.
I am using Graphics card from my old PC on the new Intel server board S1200V3RPS. First I am able to install OpenSuse 13.1 without inserting Quadro graphic card. Then I insert the graphics card and try to start the system. At the time of startup, I see garbage on the two monitors I have connected to the graphics card. Then the linux system loads and the card appears to be working fine and I am able to install legacy drivers for the card on the linux systtem.
However, the issue is that I do not have any access to BIOS screen at the time of startup. Please let me know how can I fix this?
Silvia_L_Intel1
Amit0001, since you are using an Intel Server Board, I moved this thread to the Server's community in order to get assistance.
David_A_Intel
I found a similar case being handled by our Intel® Customer Support group. Please let me know if you have already engaged support with our support group.
achau10
Dear David,
I did send the email to Intel® Customer Support group as well. They suggested the option to diable onboard video graphics. Upon doing so, I get blank screen instead of garbage value during startup. When opensuse loads up, everything works fine. Anything before that is blank. The issue is still not resolved.
David_A_Intel
I am going to report this to our support group for proper follow up as this might help us expedite the resolution of your case.
FPere14
i´m with the same problem. Are there any news about this?
David_A_Intel
I am aware that this case is already being handled by our Intel Customer Support team. I am going to make them aware of this situation to provide an update.
Salem_W_Intel1
Hi, Fabio!
For the particular video-related situation your Intel server system is exhibiting, we would highly recommend contacting our http://www.intel.com/p/en_US/support/contactsupport Customer Support team. As you contact them, please, make sure you have the system in question handy for troubleshooting.
achau10
No solution found for this issue. Since the system is stable for me now and I do not need to enter bios screen as often, I gave up on the issue. Please let me know if you were able to get to the bottom of this.
Salem_W_Intel1
Hi, amit0001,
We apologize for any confusion. We do comment our last, internal communication to you via our http://www.intel.com/p/en_US/support/contactsupport?group=graphics Online Service Request indicated that we did lab-test here, with another similar board, but the scenario was not replicated. We did just notice the http://downloadmirror.intel.com/24419/eng/Release.txt Release Notes for the most current BIOS/firmware refers to a fix involving videoing. If updating to the most current BIOS/firmware (click https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=24419 here for its download), the situation still persists, we would highly recommend getting in contact our http://www.intel.com/p/en_US/support/contactsupport Support Team.
