I just set up a raid configuration on my S1200BTL but i cant see my internal 1TB storage drive. Bios does see it but Windows Disk Management does not. I figure theres a setting in bios that i need to set or a driver i need to update/install. Any help would appretiated.
Set up:
Xeon 1235
4X4GB Ram
4X320GB Raid 0 (Using on board raid)
If you're using ESRT2, and you have add a new SATA drive, you'll need to create a RAID 0 VD using that single drive before OS sees it.
Thanks for the fast response Edward! I went into the Raid Web Console and created a Virtual Disk. After creating it Disk Mangement was able to see the drive.
![](/skins/images/BC9A7A3465121B56B278007F4EE8899F/responsive_peak/images/icon_anonymous_message.png)
