hi .. I Bought S5000PSL with 4X 4Gb ram and 2X Intel Xeon X5355 but the board does not give any VGA signal. Any one help me to solve this problem
Hello Eranga,
Can you please provide us the PBA number of your system?
https://www.intel.com/content/www/us/en/support/articles/000008055/server-products/server-boards.html
Also, please provide the part number of the memory that you are using?
Did the unit work previously?
Have you tried tested different components, such as power supply, processor, etc?
Please try testing your system with the minimal system configuration, no storage devices, one memory module and check if the problem continues.
Test your system without memory, you should get 3 long beep codes. if you do not get any beeps, this means that the problem might be related, either with the processor or the server board.
Please do not hesitate to contact us again if you need further assistance.
Sergio S.
Hello Eranga,
Sergio S.
hi, yes i tested board without ram it will get 3 beep codes. Can you tel me xeon x5355 is compatible this motherboard? I attached some images of my motherboad. Im waiting for your answer. when i give power to board it will pause by lighting red 1bit led and green LSB led please refer images.
The Xeon 5355 should be compatible with your system, you can check the hardware limitation for this processor https://www.intel.com/content/www/us/en/support/articles/000006769/server-products.html here.
Have you tried testing a different power supply on your system and tried different power connectors?
Also, test your system with one memory module at the time, just to avoid any damage on the memories slots and on the memory sticks.
Sergio S.
I am following up your issue and we would like to know if there is anything else we can assist you with.
Sergio S.
First I thank you vary much. I powered up my mother board successfully. The problem is the PS. I change my 550W PS to 600W PS. Thank again your help.
Hello Eranga,
We are glad to hear that you were able to resolve your problem, please let us know if you need further assistance.
Sergio S.
Hello Eranga,
In case you need further assistance please feel free to contact us back.
Sergio S.
Topic Options
