Software Archive
Read-only legacy content
Avisos
17060 Discusiones
Cordova prepare for emulation failed: Unexpected call to process.exit()
Robson_R_1
Principiante
1.319 Vistas
One of my projects it is present the following message when I try to run the emulator
I can press the Dismiss button, but when I do this the event OnDeviceReady is not triggered. I have removed all plugins already and load them back and did not solve.I have reviewed all code and couldn´t find any reason.
In the xdk.log I have the following error lines              (full log attached)
client:emulator:[2016-03-20T01:48:36.940Z]: (1458438516940): appmobi_plus_cordova :: Emulator changing to project pluglock
client:emulator:[2016-03-20T01:48:36.949Z]: (1458438516949): appmobi_plus_cordova :: _xdkLoad for project pluglock
xdk:client:[2016-03-20T01:48:37.801Z]: (1458438517801): memmrk:    50912832    79980416
xdk:server:[2016-03-20T01:48:38.514Z]: (1458438518514): memmrk:    32029928    47481856
server:cordova-lib:[2016-03-20T01:48:39.350Z]: (1458438519350): Error in cordovaPrepare Error: Unexpected call to process.exit()
client:emulator:[2016-03-20T01:48:39.360Z]: (1458438519360): appmobi_plus_cordova :: Cordova prepare for emulation failed: Unexpected call to process.exit()
server:emulator-webserver:[2016-03-20T01:48:39.388Z]: (1458438519388): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-03-20T01:48:39.388Z]: (1458438519388): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/Robson/Google%20Drive/Android_Projects/XDKProjects/PlugLock/www/index.html
0 kudos
4 Respuestas
PaulF_IntelCorp
Empleados
1.319 Vistas
Try removing and reinstalling the plugins in that project.
Pamela_H_Intel
Moderador
1.319 Vistas
I see that you already tried removing and adding the plugins back in.
Please resend the full build log - it did not get attached properly (0 bytes).
Robson_R_1
Principiante
1.319 Vistas
Paul and Pamela,
In fact I think the remove/add of th eplugins back solved the problem. I have removed all of them, restart XDK, and add them back.
thanks a lot.
Robson Reis
Pamela_H_Intel
Moderador
1.319 Vistas
Robson - Excellent! Carry on.
Responder
