Software Archive
Read-only legacy content
Getting my emulator (AVD) started
Joseph_F_
I have just started programming in Android, and have downloaded Android SDK API level 20.
I wrote a short application, which was OK-eyed by the Eclipse environment,
configured an AVD to match my API level and tried to run it using Debug Configuration, but without success.
I tried rerunning it, waiting, and several different configurations on the AVD, but each time I came up with the same result.
I attach a file with my AVD configuration and the error messages that appeared on the console. Thanks!
Alexander_W_Intel
Hi Joseph,
there are a couple of things you can try:
  1. Check the file permissions of your AVD folder. It's located in c:\users\<your user name\.android\avd . Right click on it select properties and remove the "read only" property. Restart the Emulator.
  2. Add an SD card to your AVD. Shouldn't have an impact but for some users it helps...
  3. The advanced :-) method of solving this would be:
    adb shell
    su
    mount -o rw,remount rootfs /
    exit
    Which changes the way the file system of the emulator mounted. If you reboot the emulator you have to apply this again
Hope one of the options solves your issue!
Alex
Joseph_F_
 Thanks for your reply, Alex!
I haven't been able to implement it though:
option 1:  whenever I cancel the read_only setting in my Avd folder, after pressing OK,
it always reverts back to read only again, so when I run emulator I get the same error message.I cant understand this.
option 2: my Avd emulator has an SD card of 16GB already.
option 3: where do I type this code?
Best regards
Joseph
Alexander_W_Intel
Hi Joseph,
Option 3 would go to a command line. The adb executable is located in the {Android SDK}/platform-tools/.
Alex
Joseph_F_
Hi Alex,
I am still trying to run Android applications on my emulator, but without success.
I am working through Android tutorials, but without being able to run simple examples, progress is hard.
I am hoping to work in this field in order to support my family, so all help is appreciated.
Please find attached a file containing the latest error messages on the Console of Eclipse when I tried to run my application.
Thanks for your patience!
Joseph
Joseph_F_
Dear Alex,
While on the subject, here are some more error messages.
If you could give your take on these, that would be great!
Joseph_F_
Anyone who is having problems getting their Android emulator running , like me,
might well be advised to try the Stackoverflow.com website - Android emulator and see
thousands of Q&A on this topic.
