- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
I have an Intel E5300 processor and an Asus P5QPL-AM motherboard. The Intel Processor Identification Utility reports:
Execute Disable Bit: Yes
Intel(R) Virtualization Technology: Yes
In the BIOS I have Intel Virtualization and Execute-Disable Bit Capability enabled and I am running the latest BIOS version.
The message I am getting is:
'This computer meets the requirements for HAXM, but Intel Execute Disable Bit (XD) is not turned on. HAXM can be installed, but will not work until XD is enabled.'
It then doesn't install HAXM despite what the message says. I have attached the HAXM install log and the complete Processor Identification Utility report.
링크가 복사됨
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Hi Geoff,
can you try to reboot your system and install HAXM again? I found this in your log file:
[plain]
MSI (s) (44:78) [15:56:44:648]: Invoking remote custom action. DLL: C:\Windows\Installer\MSI4E05.tmp, Entrypoint: CheckHAXStatus CheckHAXStatus: Looking for existing reboot marker: C:\Users\Geoff\AppData\Local\Temp\{7824FFE2-E5BE-4530-91AA-C1F442FD4A83}_reboot_required This computer meets the requirements for HAXM, but Intel Execute Disable Bit (XD) is not turned on. HAXM can be installed, but will not work until XD is enabled. Please refer to the Intel HAXM documentation for more information. MSI (s) (44!70) [15:56:54:235]: Product: Intel® Hardware Accelerated Execution Manager -- This computer meets the requirements for HAXM, but Intel Execute Disable Bit (XD) is not turned on. HAXM can be installed, but will not work until XD is enabled.
[/plain]
Let me know if this helped.
Alex
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Hi Geoff,
thanks for your feedback. I will escalate this internally to get feedback from the developers on this issue.
Alex
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Hi Goeff,
can you execute the following command line as administrator and reboot?
[plain]bcdedit /set nx AlwaysOn [/plain]
Alex
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Geoff D. wrote:
Thanks Alex. That solved it!
I'm happy that I could help and your issue is solved now :-)
Alex
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
I have a same problem like Geoff, but in my case i couldn't find the option to enable/ disable virtualization technology in bios features in bios settings. So i installed intel processor identification utility to verify if VT and XD (execute disable bit) enabled or disabled. I i found that both of those are enabled. I want to ask alex that could I try the command line : bcdedit /set nx AlwaysOn and reboot? will this solve my problem too?
