Software Archive
Read-only legacy content
Installation of Intel Parallel Studio XE Composer Edition for Fortran and C++ (Linux) failed
Christoph_I_
I just tried to install Intel Parallel Studio XE Composer Edition for Fortran and C++ (Linux) (parallel_studio_xe_2016.0.047) but near the end it failed:
Step 6 of 7 | Installation
Each component will be installed individually. If you cancel the installation,
some components might remain on your system. This installation may take several
minutes, depending on your system and the options you selected.
Installing Intel(R) MPI Library, Runtime Environment for applications running on
Intel(R) 64 Architecture component... done
Intel(R) Many Integrated Core Architecture component... done
Installing Intel C++ Compiler for Intel(R) 64 component... done
Installing Intel Fortran Compiler for Intel(R) 64 component... done
Installing Intel MKL core libraries for Intel(R) 64 component... done
Installing Intel(R) Xeon Phi(TM) coprocessor support component... done
Installing Fortran 95 interfaces for BLAS and LAPACK for Intel(R) 64
component... done
Installing GNU* Compiler Collection support for Intel(R) 64 component... done
Installing Cluster support for Intel(R) 64 component... done
Installing Intel IPP single-threaded libraries for Intel(R) 64: General package
component... done
Installing Intel TBB component... done
Installing Intel DAAL for Intel(R) 64 component... done
Installing GNU* GDB 7.6 (Provided under GNU General Public License v3)
component... done
Installing libelfdwarf.so library and it's sources (Provided under GNU Lesser
General Public License) component... done
Installing GDB Eclipse* Integration on Intel(R) 64 (Provided under Eclipse
Public License v.1.0) component... done
Installing Source of GDB Eclipse* Integration (Provided under Eclipse Public
Installing GNU* GDB 7.8 on Intel(R) 64 (Provided under GNU General Public
License v3) component... done
Finalizing product configuration...
Unable to initialize transfer functionality, exiting...
I had the previous version installed (l_compxe_2015.3.187) which worked fine! Whats now the problem I did not do anything different?
Thanks!
Devorah_H_Intel
Please make sure you have all the system requirements and prerequisites as per Release Notes: https://software.intel.com/sites/default/files/managed/0b/32/PSXE2016_Release_Notes_en_US_Lin_Win.pdf
Verify that all previous installations were removed before attempting the new installation, use uninstall.sh.
If you still have an issue - please attach an install log found in /tmp/intel.pset.$USER.$HOSTNAME_*.log and /tmp/intel.issa.$USER.$HOSTNAME_*.log
Devorah
Intel® Developer Support
Christoph_I_
I meet all requirements and i used uninstall.sh to get rid of the old installation.
The compiler works perfectly fine and even a bit faster than the old version so I'm good for now. The other thing is that according to the company who sold me the compiler told me that I can install the compiler only 3 times overall. Is that really like that? I have the named licensece.
Thanks!
Devorah_H_Intel
Yes, this is correct.
The ‘Named-user’ license provisions in the Intel software EULA have changed to only allow the software to be installed on up to three systems. The Named-user license for the Intel® Parallel Studio XE and Intel® System Studio products (beginning with the 2016 release) requires that you provide host ID information for the host computer that you install the materials on.
Christoph_I_
Thanks for the help!
Luisa_C_
I downloaded the 30 day free trial of  Intel® Parallel Studio XE Composer Edition for Fortran and C++ Linux*.  the license expired allready, and I am trying to download de 30 day trial again. The program seems to be intalled but it does not run. It shows a error file "intall.sh" which I don´t know what it means.
Please, help!
Devorah_H_Intel
Please, help!
Remove all previous installations before attempting the new installation. Use uninstall.sh
Devorah_H_Intel
The original issue with Intel® Parallel Studio XE Composer Edition for Fortran and C++ (Linux) installation was fixed in Update 1.  Update 1 is available for download in Intel® Registration Center.
Devorah_H_Intel
This issue has been resolved. If you have a similar issue, do not add it to this thread but start a new one.
