Software Archive
Read-only legacy content
List Item issue with layout
Marcondes__Marcos
초급자
2,673 조회수
My APP is located into https://play.google.com/store/apps/details?id=com.Conteudo_Animal
I made a list item menu ...
When I click on any link .... a blank header and footer appear and not idea the reason
For example the first link Dicas Veterinárias should show the content on http://www.conteudoanimal.com.br/mobile/dicasveterinarias/dicasveterinarias.asp
Please advice any issue
I want to remove footer and header of 2nd link level
thanks in advance
Marcos
0 포인트
1 솔루션
Kirtan_S_1
새로운 기여자 I
2,673 조회수
I got the solution!
For your
<div class="upage vertical-col panel" id="mainpage" data-header="af-header-6">
change it to:
<div class="upage vertical-col panel" id="mainpage" data-header="none" data-footer="none">
This will remove the header and footer on the main page, and for all the <a> elements,
set
target="_self"
This way, no headers/footers, and adsense works!
원본 게시물의 솔루션 보기
0 포인트
14 응답
Amrita_C_Intel
2,673 조회수
Hi Marco,
Which XDK Version are you using? Are you using  app designer or which framework you are using for this app?
0 포인트
Marcondes__Marcos
초급자
2,673 조회수
Intel XDK shows on top right 1995
I tried blank, list view template, with and without cordoba
When I add list view the problem begins ....
I need help
0 포인트
Kirtan_S_1
새로운 기여자 I
2,673 조회수
For the <a> tag that links you to the page, what did you set the href to?
Also, the <a> element should be inside your <li> list item element, not wrapped around.
0 포인트
Kirtan_S_1
새로운 기여자 I
2,673 조회수
Also, I tried recreating your problem, with XDK version 1995, list view template.
Try:
<ul class="list">
                <li><a href="http://www.conteudoanimal.com.br/mobile/dicasveterinarias/dicasveterinarias.asp">Item 1</a></li>
                <li><a href="#item2">Item 2</a></li>
                <li><a href="#item3">Item 3</a></li>
                <li><a href="#item4">Item 4</a></li>
                <li><a href="#item5">Item 5</a></li>
                <li><a href="#item6">Item 6</a></li>
                <li><a href="#item7">Item 7</a></li>
                <li><a href="#item8">Item 8</a></li>
                <li><a href="#item9">Item 9</a></li>
                <li><a href="#item10">Item 10</a></li>
                <li><a href="#item11">Item 11</a></li>
                <li><a href="#item12">Item 12</a></li>
            </ul>
Most of the code is default, however I changed the first List Item to the link you provided in the question.
It works in both HTML5 and HTML5+Cordova
0 포인트
Marcondes__Marcos
초급자
2,673 조회수
Kirtan,
First thanks for trying helping me
I did something wrong ... I did what you said and nothing changed to me
I zipped and sending the project files
thx
Marcos
0 포인트
Kirtan_S_1
새로운 기여자 I
2,673 조회수
Do you want to remove those headers/footers completely, or actually put text in them?
Also, do you care to maintain the theme?
E.g
Android: black bacground etc.
IOS: gray background etc.
0 포인트
Marcondes__Marcos
초급자
2,673 조회수
Kirten,
Remove completely header and footer
Another issue is with those the adsense code not showing like
0 포인트
Kirtan_S_1
새로운 기여자 I
2,674 조회수
I got the solution!
For your
change it to:
set
target="_self"
0 포인트
Marcondes__Marcos
초급자
2,673 조회수
Kirtan,
Worked 100% .... thanks a lot
Do you have a website or blog or something else ?
Do you work on Intel ?
cheers
Marcos
www.conteudoanimal.com.br ;
0 포인트
Kirtan_S_1
새로운 기여자 I
2,673 조회수
Actually, no I don't work for intel, and I don't have a blog/website.
0 포인트
Marcondes__Marcos
초급자
2,673 조회수
Twitter ? Facebook ? Linkedin ???
Something you want to promote ???
0 포인트
Kirtan_S_1
새로운 기여자 I
2,673 조회수
No, I don't have accounts for any of those
0 포인트
Marcondes__Marcos
초급자
2,673 조회수
Well .... thx a lot again
Helped me a lot !!!
thanks again and again !
0 포인트
Kirtan_S_1
새로운 기여자 I
2,673 조회수
no problem
0 포인트
응답
