Software Archive
Read-only legacy content
17061 Discussions
Performance of kmp_affinity explicit on Intel Xeon Phi KNC
jaisimha_sai_k_
I am a new MSc student working on Intel Xeon Phi KNC. For my current project, I am running NAS parallel benchmark BT on xeon phi coprocessor with two different affinity patterns using KMP_AFFINITY explicit
scenario 1: running with 40 threads with 4 threads per each physical core (using 4 virtual cores per core and total of 10 physical cores )
results from VTune amplifier:
Elapsed time: 73 seconds
L2_DATA_READ_MISS_CACHE_FILL :76,150,000
L2_DATA_WRITE_MISS_CACHE_FILL: 616,750,000
L2_READ_MISS_CACHE_MEM_FILL : 1,862,300,000
L2_DATA_WRITE_MISS_MEM_FILL: 1,964,750,000
scenario 2: running same benchmark with same 40 threads but with one thread per each physical core (using total 40 physical cores)
Elapsed time: 48 seconds
L2_DATA_READ_MISS_CACHE_FILL :272,800,000
L2_DATA_WRITE_MISS_CACHE_FILL: 104,200,000
L2_READ_MISS_CACHE_MEM_FILL : 1,524,350,000
L2_DATA_WRITE_MISS_MEM_FILL: 2,548,200,000
Though scenario 2 has significant amount of write misses, around 580 million more than scenario 1, scenario 2 is taking significantly less time to complete than scenario 1.  I also read KNC performance can be peaked by using more than one thread per core. I am confused why the first configuration takes so much time. I expected it to be faster. What might be the reason for this? I would really appreciate your help!
McCalpinJohn
As I mentioned in the other forum (https://software.intel.com/en-us/forums/intel-moderncode-for-parallel-architectures/topic/714924#comment-1898880), you need to evaluate whether this code is likely to be compute-limited or memory-access limited.  The total traffic for the 2 cases above is almost the same, but the compute resources are substantially different.  Interpreting these results as indicating a compute-bound application seems like a reasonable start.
McCalpinJohn
jaisimha_sai_k_
Hi John
I observed computational resources for both cases, it shows 2430 Mops for first case and 4079 Mops for second case. so what you said seems correct, their computational resources are different. Thank you for your suggestions!!
SergeyKostrov
Valued Contributor II
>>...two different affinity patterns using KMP_AFFINITY explicit... If you try KMP_AFFINITY set to scatter or balanced you should get highest performance numbers similar to scenario 2. Also, when these KMP_AFFINITY modes are used CPU #1 and CPU#2 share L2, and CPU #1 uses exclusively L1, and so on ( execute cpuinfo for more details if you're using a Linux OS ). High number of cache misses, for both your cases, indicates that there is a problem with a test case and if this is an OpenMP processing then data partitioning is not done correctly.
James_C_Intel2
The initial question says "KNC". It is KNL where tiles are used and two cores share an L2$.
