Software Archive
Read-only legacy content
公告
17060 讨论
[RESOLVED] Cannot login to Intel XDK v3900
James_H_4
初学者
23,661 次查看
The login problem should now be resolved (as of March 30 at 11:30 PDT). The workaround referenced in this thread should no longer be required. If you previously applied the workaround you do not need to "undo" or change anything, the workaround is compatible with the fix. You may be prompted to re-login if you were previously logged into the Intel XDK. The issue was due to the deployment of an incompatible authorization certificate.
------------------------    workaround no longer required    ------------------------
Please see this post > https://software.intel.com/en-us/forums/intel-xdk/topic/720758#comment-1900352 < for a workaround.
------------------------    original post    ------------------------
I received the following error.
The webpage at https://signin.intel.com/?appid=515&TYPE=33554433&REALMOID=06-900bfa3b-39d4-4f49-95b0-099aaaf63c20&GUID=&SMAUTHREASON=0&METHOD=GET&SMAGENTNAME=$SM$QnJMmP%2bN6gMN%2fVVnfgk5wOmI3XqRSADYbdE9VPLR1oGltLZwYJ6CRfT8RxFdy4HV&TARGET=$SM$HTTPS%3a%2f%2fsfederation%2eintel%2ecom%2ffederation%2fXDK_App_Center%2easp%3ftCulture%3den-US might be temporarily down or it may have moved permanently to a new web address.
0 项奖励
89 回复数
PaulF_IntelCorp
4,245 次查看
Robert T. wrote:
This bug affected me too. The workaround works fine for me.
During my app testing I had to change the system time, and this is exactly what caused the problem.
Maybe that will help you with the bug fix?
Interesting observation! How far off was your system clock?
0 项奖励
Artur_G_
初学者
4,245 次查看
Paul, to be honest, I am getting upset about this situation. It's about several days I have this problem and cannot use this software to start my educational course for HTML5.
The copy&pase option does not work in my command prompt window (terminal). I cannot type all the instructions which you wrote because of the inconvenience. Do you have any other, optimal solution to this problem? I am fed up and want to have a precise and well-though, a single solution to this problem!!! Otherwise,  have to cancel ... too much time and nerves are spent on errors of your software.
0 项奖励
PaulF_IntelCorp
4,246 次查看
Artur -- what is the course you are trying to use? If you are using the edx course it does not require the XDK. Using the standalone Brackets editor is sufficient to go through that course.
There is no other workaround, only the one we provided in this thread. Make sure your system date and time is correct. You should not have to type anything, copy and paste the command-line options, they will work exactly as typed into the post. The workaround instructions are precise, if you are having trouble following the instructions it would help if you recorded your process of walking through the steps to help me understand where the confusion is so I can improve the instructions.
0 项奖励
Bunthit_W_
初学者
4,245 次查看
Nothing work.
First time trying to use XDK, my OS is Windows 7.
0 项奖励
frendy_k_
初学者
4,245 次查看
thanks very help
0 项奖励
GMenv1
创新者
4,245 次查看
I have the problem as well when my computer is not connected to the internet.  I have a workaround that is quite ugly at the moment but waiting for the official fix
​Question though, why do we need to be logged in constantly?  Reason I am asking is that I travel quite a bit and often do not have a connection and it creates havoc on the xdk stability.  Since all the work is done local, is there a reason why we're going the login/server ping?
Thank you, Gregory
0 项奖励
Carlos_Z_
初学者
4,245 次查看
Thanks. It worked!
0 项奖励
PaulF_IntelCorp
4,245 次查看
In general, the only thing you need the login for is use of the Build tab (other than the new PhoneGap/Cordova export feature) and the Test tab (to push/pull your app into App Preview). The other features of the XDK do not require login to work.
0 项奖励
PaulF_IntelCorp
4,246 次查看
Bunthit W. wrote:
Nothing work.
Please follow the workaround instructions carefully.
0 项奖励
Jackie_A_
初学者
4,246 次查看
Hi, Thanks. It worked.
0 项奖励
PaulF_IntelCorp
4,246 次查看
Bengt R. wrote:
My login time is out !  Do you realy meen I have to wait a week or more before my XDK works again.
I have download xdk but have not been able to log in.
When do you think the login problem is fixed
Please use the workaround. In the workaround it clearly states that if your login times out you will have to go through the workaround process again. We are working on a solution to this problem, when that happens you will no longer need to use the workaround, until then, unfortunately, the workaround is required.
0 项奖励
cesar_b_1
初学者
4,246 次查看
I think it's very wrong what happened. I installed Android Studio to start using it
0 项奖励
Viachek
初学者
4,246 次查看
It works! Thank you :)
0 项奖励
akhil_t_
初学者
4,246 次查看
it worked for me. Just follow those step by step.
0 项奖励
Franck_Serge_P_
初学者
4,246 次查看
It's working. Big thanks!
0 项奖励
Billel_G_
初学者
4,246 次查看
work for me thanks
0 项奖励
Nipun_A_
初学者
4,245 次查看
Unable to login in through intel xdk app.
Version 3900
When will there be an actual fix?
0 项奖励
madhi
初学者
4,245 次查看
my didnt worked !!
even i copied the cookies from the default folder of chrome
please help!! i am not able to work on it
0 项奖励
madhi
初学者
4,240 次查看
nothing worked to me too please help v3900
windows 10 pro
0 项奖励
Szilvia_E_
初学者
4,240 次查看
I'm in the same situation as Arthur, I'm on the HTML5 for W3C edX course where XDK is the tool of demonstration. I can't log in and I'm on Linux (which seems to be a neglected OS regardless it is the preferred OS by the developers around me).
Update: As it was recommended, I logged in with Chrome and copied the ~/.config/google-chrome/Default/Cookies into  ~/.config/XDK/Default and  ~/.config/XDK-Wrapper/Default  , but I still see the error. The
INSERT INTO "cookies" VALUES(13135034081914716,'appcenter.html5tools-software.intel.com','xdkEdition'...
is in the Cookies file, so unless the cookies are encrypted with a key that changes for each instance, it should work.
Thank you for your help,
Szilvia
0 项奖励
saisunee_a_
初学者
4,240 次查看
It's worked for me. Thank you sir !
0 项奖励
回复
