Software Archive
Read-only legacy content
RESOURCES (including downloads)
JamesR
New Contributor II
Here are links to the available downloads.
An introductory explanation can be found in "Knights Corner: Open source software stack."
Source Code: MPSS downloads
The **LATEST** MPSS release KNC_gold_update_2-2.1.5889-14 (dated March 7 2013) is now available here:http://software.intel.com/en-us/articles/intel-manycore-platform-software-stack-mpss
This document can be navigated to from http://software.intel.com/mic-developer and going to 'Tools'.    From now onwards we will maintain that document as the 'go-to' place for the MPSS.
The last 1-2 archived versions of the MPSS can be found here: http://software.intel.com/en-us/articles/intel-manycore-platform-software-stack-mpss-archive
Older information follows....
Previous "Gold" MPSS 2.1 Initial Release, version .4346-16  / Nov 2, 2012
These KNC_version_OS.gz downloads correspond to the particular build for the given operating systems while the readme.txt and install.txt files apply to all.
More information and instructions are in readme.txt, releaseNotes.txt and install.txt.
Please note: the MPSS download files marked '.gz' should end in '.gz' when downloaded; most browsers leave the extension alone, but Windows Explorer may rename the file. If this affects you, we recommend renaming the file to the proper extension after downloading.
Source code: gdb downloads
The gdb download is now included in the MPSS download above, so it is no longer needed as a separate download.
Knights Corner micro-architecture related information: Documents
An introductory explanation can be found in "Knights Corner micro-architecture support."
a_kaliazin
Thanks James The main package - KNC_gold_update_1-2.1.4982-15 - is indeed available and accessible from the open source site your quote and from the registration center, as part of the Parallel Studio pack, but it lacks certain features, unfortunately. And they are essential to use Xeon Phi efficiently at any HPC system. The missing packages in the previous release were called KNC_gold_isv-2.1.4346-16 which contains intel-mic-sysmgmt-devel RPM and KNC_gold_llapi-2.1.4346-16, which contains intel-mic-llapi RPM. The latter is needed, at least to us, in order to build Torque with Xeon Phi support. And I don't know how to get it. Is there any place I can access those packages asap? cheers, Andrey
Bsc_Cns
Hello Andrey,
Have you been able to find the package intel-mic-sysmgmt-devel-2.1.4982? We also need it.
Thank you
Cristina_I_Intel
a.kaliazin wrote:
Thanks James
cheers,
Andrey
Hello Andrew,
The packages you speak about are needed in order to improve the performance or just to make to work something? I'am asking beacuse I installed this MPSS version but unfortunetly the performance was worse so I downgraded the MPSS to 4346-16 version.
Is there a newwer version of MPSS? (newer than 4982-15).
Thank you,
Cristina
ovizun_s_
Thanks to share this . I knew intel is the largest service way and you will prove it . thanks again.
BelindaLiviero
4982-15 is still the latest available.   We will always announce and post the latest version in this page: http://software.intel.com/en-us/articles/intel-manycore-platform-software-stack-mpss   (accessible via http://software.intel.com > Tools & Downloads > MPSS link).
BelindaLiviero
to answer the other question in this forum thread:   the *sysmgt* and *llapi* packages will be made available in the next MPSS release (keep checking on the aforementioned page regularly).   I will defer to the documentation that will come with the packages on what they're most helpful for (but yes, may be useful for optimization purposes)
PONRAM
highly helpfull
GHui
I cannot download KNC_gold-2.1.4346-16-rhel-6.3.gz. Thanks.
Ali_S_3
It just links to an error page. Can we upload this please?
TimP
Loc_N_Intel
Hi GHui,
You can also visit the MPSS Archive page (https://software.intel.com/en-us/articles/intel-manycore-platform-software-stack-mpss-archive) where you can download the last two previous versions of MPSS 2.1 . Thank you.
buck_d_
Hi All,
Looking for some guiadance on a project I am working on and could use some help. Please message me at buck@bimboxusa.com. We are working to map out our development path for the processing of large point data.
