Software Archive
Read-only legacy content
f7-card height problem
Andrejs_V_
XDK 3357
Hi, all!
I got a trouble with f7-card component. After check-on for title and/or footer component's height do nit changed.
Only manually adding style="height:.... ; padding-top:...." for component and for header/body/footer can help me/
Is it bug or I do something wrong?
Thank's for answer
PaulF_IntelCorp
I've asked one of my colleagues to take a look...
Brian_W_Intel
Hey Andrejs,
In order to get the header/footer to show, you'll need to add some content to them, either through text or an image. Simply checking the box won't add anything, you'll need to type some text into the Header/Footer boxes to see any changes.
Brian
Andrejs_V_
Hmmm, what version of Framework7 used in XDK?
I overwrite framework7 folder with ...\Framework7-1.4.2\dist from Framework7 1.4.2
