Software Storage Technologies
Virtual RAID, RSTe, and Memory Drive Technology
Looking for RAID, VROC? You found the forum to ask questions!
351 Discussions
I try to reinstall IDA, but always got the windows asking if I want to uninstall the program. I have tried the special uninstall program, but it does not help. IDA will not install. Something wrong in the register? (Bjorn
BHjal
AlHill
What OS? WIndows 10? What version? 1909?
What anti-virus are you using?
What firewall are you using?
Are you blocking any ports? IDSA accesses localhost on posts 28385-28389. It also connects to www.intel.com, downloadcenter.intel.com, and downloadmirror.intel.com, all on port 443 (HTTPS).
Doc
BHjal
Windows 10 Home, 1909.
Bitdefender Total Security & Windows Firewall
I shut everything on Bitdefender and Firewall, but the problem persist...
BR/Björn
LeonWaksman
  1. Download the Microsoft Uninstall Troubleshooter https://support.microsoft.com/en-us/help/17588/windows-fix-problems-that-block-programs-being-installed-or-removed
  2. Run it, choose uninstall option and select the IDA entries for uninstalling.
  3. Now, you will be able to install the IDA.
Leon
BHjal
Sorry, but it does not help. Can't find IDA i the list.
/Björn
LeonWaksman
See the attached video how to do this.
Leon
BHjal
Thank's but I have tried that. The problem is that I can't find IDA in the list!
/Bjorn
AlHill
Uninstall bitdefender as a test and use windows defender.
Doc
Leonardo_C_Intel
Hello BHjal
Thank you for posting in the Intel Community.
Can you please provide a picture of the behavior that you are having?
What is the full Intel® software name that is having this issue?
Leonardo C.
A Contingent Worker at Intel
BHjal
When I try to install Intel DSA I always get this windows. If select uninstall I get the same window again when try to reinstall... I have tried suggested fixes above, but nothing helps. I have also removed some key for IDA in the register.
But no change..
BR/Björn
Leonardo_C_Intel
Hello BHjal
The video that was shared by LEON WAKSMAN works to uninstall and install Intel® Driver & Support Assistant (Intel® DSA), in fact, he uninstalls Intel® Driver & Support Assistant on the system, I am curious to know why are you looking for "IDA" and what software are you referring to by "IDA"?
In case you are referring to Intel® DSA try completing these steps:
  1. Uninstall the existing Intel® Driver & Support Assistant (Intel® DSA) tool in the system using the Uninstaller tool.
  2. Download and install the latest Intel® DSA version from here.
Can you provide me with the Intel® System Support Utility for Windows* report and a video similar to the video shared by LEON WAKSMAN showing the issue that you are having?
Leonardo C.
BHjal
Skärmbild (32).pngHi,
No use showing a video. I run uninstall and it looks ok. Run Install and it ends with this window. It always end like this.
Enclose the system file.
BR/Björn
LeonWaksman
Hello BR/Björn,
  1. You should download and run Microsoft tool: https://aka.ms/Program_Install_and_Uninstall
  2. Press on Uninstalling
  3. After short scan you should fin in the list Intel Driver && Support Assistant (at 0:00:27 on my movie clip). Click on it and click Next.
  4. After uninstalling the IDSA installer, you should be able to install latest IDSA.
Leon
BHjal
I have tried, as I wrote earlier there is no IDA in the list!!!
BHjal
I found two logs from IDA from latest try, enclosed
BHjal
BHjal
When I run the program I don't find IDA in the list and select "not in list". Then I get a question to enter the code for the program. Do you know the code?
LeonWaksman
No, I don't know the code, however will pass your question to the S/W group working on IDSA.
Leon
Leonardo_C_Intel
Hello BHjal
Thank you for reporting the behavior that you are having, we are currently working on a new release for Intel® Driver & Support Assistant (Intel® DSA) by January 30th, we would appreciate if you can test this release completing a clean installation of Intel® DSA with the steps I provided previously.
I will be following up by then on this thread
Leonardo C.
Leonardo_C_Intel
Hello BHjal
I would like to update this thread and share with you that the new Intel® DSA version v20.1.5 (https://downloadcenter.intel.com/download/28425/Intel-Driver-Support-Assistant?product=128824) is released.
Can you try running the Intel® DSA Uninstaller (https://downloadcenter.intel.com/download/29376/Intel-Driver-Support-Assistant-Uninstaller) and installing the new Intel® DSA version on the system?
Leonardo C.
Leonardo_C_Intel
Hello BHjal
Have you been able to test the steps provided?
Leonardo C.
