Hello all,
when I connect a Thunderbolt eGPU to my Lunar Lake XPS 13 (258V), Touchpad, Touchscreen, Wifi, Sound and all USB devices crash. I can only hard shut down the device.
I've tried all the suggestions in the threads of this forum but with the same result as all other reports state.
Things I've tried:
- Plugging in before boot and booting with eGPU connected
- Installing drivers in secure mode
- Removing all GPU drivers and reinstalling
- Reinstalling Windows and using a fresh, plain installation
All drivers and Windows are up to date.
I can confirm that the eGPU works without any issues on a old laptop with Intel 11th gen processor (1185g7).
As there are the same reports by multiple persons with different systems I assume there is a fundamental issue with Lunar Lake systems and Thunderbolt.
I've created the thread as Intel mods asked to create a separate thread.
Hi @Marcus_St,
Thank you for posting here in our community. To effectively diagnose and address the issue you're experiencing,
- Please provide the SSU log report and share it here so I can review your system's configuration.
- Are there any error message in the Device Manager?
- Have you tried this set up before?
This issue might be related to how Thunderbolt is integrated into your system’s motherboard, rather than an issue stemming directly from the CPU itself. We will figure this out once I have the logs.
Warm regards,
Randy T.
Hello Marcus_St,
I wanted to check if you had the chance to review the questions that Randy posted. Please let me know at your earliest convenience so that we can determine the best course of action to resolve this matter.
Jed G.
Hello Marcus_St,
Since I haven't heard from you, I will proceed with closing this case. Please note that it will no longer be monitored. However, you may submit a new ticket if you need further assistance in the future.
Randy T.
An update to Windows 11, released end of July, should address this issue. Recommend installing the Windows 11 update and testing if your issue is solved.
