Wireless
8693 Discussions
AX200 - bluetooth disconnection with multiple game controllers
claudspeed
I have a Legion 5 Pro 16ACH6H (from 2021), with Intel Wifi-6 AX200 160MHz card with integrated bluetooth, driver: 22.190.0.4 (from 23/11/2022), OS: Windows 11.
Using an external bluetooth dongle I can connect any number of bluetooth controllers (joypads) of different or same manufacturer.
If I use the intel bluetooth AX200 card integrated in the Legion 5 pro I'm only able to connect one controller. If I connect another the first one disconnects.
No problem on other laptops I've tried with the same controllers.
Other users have complained about this here, but you ignored them.
This IS clearly a driver bug. I am a software engineer, btw.
Can you escalate and try to have this fixed asap, please?
DeividA_Intel
Hello claudspeed,
Thanks for letting me know the outcome from the manufacturer. Allow me to check this issue internally to confirm what would be our next step.
Deivid A.
DeividA_Intel
Hello claudspeed,
Thanks for your patience. Based on the investigation, I would like you to try the following:
1. Reset and delete all the existing Controllers.
2. Pair them again manually.
3. Update the PS5 Controller Software by connecting them to a PS5 directly.
4. Update the BIOS if pending updates and reboot.
5. If the issue persists, I recommend you to reinstall the operating system.
Deivid A.
claudspeed
Hi Deivid A.,
I tried this already, did It again for you. It didn't work.
I have the latest firmware, see screenshot:
I have the latest Lenovo Bios: GKCN59WW updated last week through Lenovo Vantage.
I did a clean install of Windows 11 x64 last week, the issue persists. Bluetooth driver 21.0.0.4 works, any of the above versions don't.
Everything seems to suggest that the driver has a bug introduced after 21.0.0.4, that makes the Dual Sense use Its MAX polling rate (1000 Hz) while other controllers are connected, causing their connection to drop or be very unstable and then drop after 2 minutes.
In fact in 21.0.0.4:
- Dual Sense connected alone: shows 1 ms latency in DS4Windows
- Dual Sense + Dualshock 3 connected at the same time, I see from DS4windows that the Dualsense has a latency of 4 ms, while the Dualshock 3 has 15 ms, suggesting that the Dual Sense has dropped the polling rate to 250 Hz, to allow more bluetooth bandwidth to be used for the second controller.
On the newer drivers:
- Dual Sense + Dualshock 3 connected together, Dual Sense has 1 ms (which would be 1000 Hz polling rate) and the Dualshock 3 has a very variable latency ranging from 25 ms to 35 ms and disconnects completely after a couple minutes.
I tried connecting the Dualshock 3 and the Nintendo Switch Pro controllers together, both have a very low polling rate, and the connection seems to be working fine and be pretty stable. The moment I connect the Dual Sense, the other two disconnect.
I hope this is helpful and you give this information to your colleagues.
will6
Valued Contributor I
Dealing for two years with Intel AX cards. OEM, built in, third party. All have the same problem reported here.
ESCALATE.
DeividA_Intel
Hello claudspeed,
I am sorry to know that the issue is still present. I will check this issue internally and review how we can help you with this issue.
I will post back as soon as possible.
Deivid A.
claudspeed
Hi Deivid A.,
thanks for your help, but please try to be more useful. I've been troubleshooting this with you for almost a month, nothing of what you suggested helped. It's clearly a driver issue as me and other users have told you countless times. It has nothing to do with my software configuration or my hardware. Please consider the feedback from @will6  and @Efren as well, which have different configurations, different cards (still AX cards) and have the same exact issue with your bluetooth driver.
We can arrange a skype call to troubleshoot this together with your colleagues If you want, but I don't have infinite time and I don't work for Intel.
No more generic troubleshooting please, It's pointless.
Efren
Hello @claudspeed
I have a PC with a PCI Intel Wi-fi 6E AX210 160MHz (driver 22.200.0.6) with integrated Bluetooth (driver 22.200.0.2) and I have the exactly same problem than you. The problem is not about laptops, the problem is about intel card or intel driver.
What is the model of your bluetooth dongle? Do you have a good low latency?
I want to give up Intel.
claudspeed
You mean my usb dongle? I have a very generic chinese dongle with the label "CSR V4.0" on It, It has the csr8510a10 chipset. I paid It like 5 euros and It works fine unlike Intel's bluetooth card.
Dualsense alone: 1ms
Dualsense + Switch Pro => Dualsense: 2ms, Switch Pro: 10ms
Range is not the best though, like most usb dongles, but It works fine 3 meters away when plugged in a usb on the side of the laptop.
will6
Just avoid the cheap no brand 1 dollar dongles. They will be on par with Intel one. Some are even better, but no way to tell.
Just get a tplink UB400 or UB500.
With UB500 and two dualsense, ds4w report around 2 to 3ms of latency for each controller with both connected.
The only problem of usb dongles is connecting them on the ports on the back of the PC. This will limit their range severely.
Efren
Thanks, @will6
3ms is a good latency for two dualsenses!
I asked for the dongle model because I got an Ugree bluetooth 5.3 that give me the unbelievable 30ms of latency for one dualsense. I do not recommend Ugreen dongles for anyone.
DeividA_Intel
Hello claudspeed,
Thanks for your patience. In this case, the last recommendation would be to roll back to the previous working version from the laptop manufacturer until the upcoming driver release. However, we do not have a date for the new release.
Please keep in mind that this thread will no longer be monitored by Intel.
Deivid A.
claudspeed
Hi Deivid,
thanks, I'm relieved to know that this will be fixed in the upcoming release. The latest driver 22.210.0.3 (08/02/2023), still has the issue, I home to see this issue fixed in the version after that.
I will roll back to 21.0.0.4 for now.
Thanks for your support,
have a great day.
will6
The 3 years old working driver is only compatible with ax200.
If you got any card newer than that (ax201, 210, 411, etc), the solution is to buy a better brand adapter.
Nice.
will6
If that ever happen, remember to report back here. Since many users had disabled this faulty card and won't check for new drivers.
BTW, drivers here https://rog-forum.asus.com/t5/intel-700-600-series/drivers-intel-ethernet-wifi-bluetooth/m-p/878985 are updated sooner than Intel site if you want to try newer ones.
claudspeed
Thanks for the link, I will report back here for sure, fingers crossed
will6
A new driver was releases this week.
But don't think it will solve anything.
22.210.0.x
Efren
@will6
You are right. I just installed the new driver and tested it with 2 dualsenses. Same problem: keeps disconnecting...
claudspeed
What new driver has been released this week? I'm still seeing 3/24/2023 as the latest release date on Intel's website
will6
Yes, was talking about that driver that was released some days ago.
Didn't see any report about that. But seems didn't fixed anything.
Also there is a release notes with the fixes on every release.
BTW that driver was released many weeks ago on the Asus forum.
will6
New driver was released today on Asus forum in the link posted earlier
22.220.0.3
will6
Tried the new driver. I was not using Intel BT for a few months.
It's just terrible. How can they even sell this trash?
I couldn't connect a dualsense and a BT headset for their BW limitations. Headset keep disconnecting.
Even my Wiimote doesn't have speaker audio with this trash (never seen this on any other BT, including BT 2.0 from 10 years ago)
Disabled again this faulty mess.
